Corian
[2574]
29 Nov 2002
I need some matching Corian for our existing galley worktop - does anybody know a helpful supplier who will supply and cut this v expensive stuff?
robih
sailorman
21 May 2003
Here or thertemp ashore
u can onl buy from an approved manufacturer. /forums/images/graemlins/shocked.gif
items manufactured from your drgs or templates.
its a complete stitch-up. /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
i have looked into this for my galley
[2574]
29 Nov 2002
sailorman,
thanks for that - how dull! Have you found an alternative to Corian that does the job? Or are you simply frustrated by the whole business?
rob
richardabeattie
9 Jan 2004
Wiltshire
There are similar products called crystolan and crystalite - a bit cheaper and possibly harder - but all these materials seem ludicrously expensive. Where are the offcuts we need!
Mudplugger
12 Jun 2003
East Coast/ North Sea
Might be worth having a look @ Homebase, They are stocking Winther Browne Fire surrounds, Heat & scratch resistant, in panel sizes of 930 x 930mm. and 1332x362mm at sensible prices... about 15mm thick.. Very helpful lady on 0208 884 6000. HTH
kandoma
19 Dec 2004
Switzerland
if you go to http://www.t-klaeusler.ch/products-corian-extra-lights.htm you will see all the available corian.
This website is from the official distributer Switzerland and sells cut offs. You should be able to find the same for GB. Every carpenter here has access to this stuff for building kitchen tops. The minimum thickness sold is 8 mm. It can be glued and repaired similar like wood, but needs some special skills.
If everything fails, ask a company, building the interior of supermarkets. They will know, where to get it from.
Peter /forums/images/graemlins/smirk.gif
