lw395
Any recommendations for suppliers and different brands?
I need some worktops, would be about 5 or 7 sqft roughly.
TIA.
TIA.
i have some white Corian in a kitchen area. 40 years, stain free.Hamble Yacht Services will supply and fit them - but they will not be cheap! Go for a dark colour - our boat was built with worktops in white Corian lookalike - it looks beautiful, but I'm always terrified of staining them.
DONT go fo a dark colour!
You will see every scratch and blemish. We have then on a Squadron 65 and every season they had to be polished back up and looked terrible after weeks
The worktops in my Bavaria are made of a solid laminate, about 12mm thick. It's highly durable, as tough as old boots, and very strong. I believe it's called Duropal Compact, see http://www.duropal.co.uk/samples/compact-collection-2018-2020/
TIA.
Good luck finding something useful. I'm looking to replace a standard kitchen worktop in my galley with something that can handle more moisture.
There's barely any information about compact/solid laminate worktops at all in the UK and even less on stores where you can just order some in the size/colour want.
Worse for since my boat is abroad so even less choice. I have found something called Compacmel Plus, that is designed for high humidity environments, but I doubt if it could stand up to kitchen abuse.
My suggestion for using Quartz was for house kitchens as I thought that was what the enquiry was about.
Many boats use Formica stuck on Ply but Corian, Duropal etc would be very good
Ah, the OP wasn't exactly specific, was he? But why post here if it's a house-related question?
You were not exactly wrong, it's not for a boat. Quartz, Marble or other polished rock are a good idea, but the advantage of Corian etc could be greater range of colours.
