pvb
Reading the info on the Meguias 45 "Polish" tells the story as to what that produce does.
Meguiar’s #45 Marine/RV Polish is designed for the special needs of boats and RVs. Because both boats and RVs are made of fiberglass, they have a porous gel coat. This polish is designed to penetrate the pores and remove contamination while depositing nourishing oils. These oils wet the gel coat to create a rich, vibrant shine. Once you apply a coat of Meguiar’s #56 Boat/RV Pure Wax, your boat or RV will have a high gloss shine that withstands the elements, even salt water.
This is not a filling the pores of the GRP , deep cleaning the GRP then filling the pores with an "oil". This is like waxing as you say which adds a smooth layer on top of the GRP. The waxing of the next produce in the range also adds a layer of protective material that also makes the surface shiny.
Polish is a general term for getting a shiny surface. Burnishing is also a way to get a shiny surface without removing material
Pedantic mode off
Painting with a gloss paint can also give a shiny service and painting is not considered polishing.
Seems you agree with me that Meguiars 45 Polish is non-abrasive, and that polishing is a term for getting a shiny surface. It doesn't have to involve removing gelcoat.
