greeny
10 years down the road with CC. and very happy with it. Virtually no fouling on the hull at all each year, and my boat has not moved much this last couple of years. The fouling that is there just washes off after a couple of days out on a trip.
Application is extremely important. Mixing well and regularly to keep the copper particles in suspension is important. Abrading with scotchbright did not work for me. Used 100 grit to give it a light sand by hand to expose the copper.
If your application is poor and you have a rough finish, orange peel effect, then any sanding only takes the peaks off and leaves the troughs still covered with epoxy. Thats where the fouling will stick. Make sure the application finish is as as smooth as possible or you will be sanding lots of it off later to get it flat and expose the copper evenly.
I would agree that the first year for me was a bit dodgy and i was unsure that i had made the right choice, but i believe it was just not abraded sufficiently. 10 years ago, scotchbright was the recommendation and that is not enough to get the epoxy coating off the copper particles in my opinion. After the first year I lifted out and sanded with 100. It's been working ever since.
10 years down the road and quids in now. Very happy with the choice.
Atlantic waters Portugal, Spain.
Berthed in Portimao, river estuary, saltwater, not brackish except for when we get big rains. Not often.
p.s.
for those who are not sure whether to take the leap.
why don't you get the local applier to put a few test areas on your hull at next lift out. a few small (6 inch squares) dotted around will test it in your area on your boat. Then you'll know for sure whether its worth spending your money after a year.
p.s.
