rob2
Possibly not as whilst the pressure jet will erode the coating, the amount of water flowing over it will leach out the biocides. Basically, an eroding antifoul should not be scrubbed or pressure washed - period. A hard scrubbable antifoul holds its biocides in a tight matrix and they leach out much more slowly, so you can wash and scrub, sort of halfway stage to Coppercoat and its ilk which should survive pressure wash and scrub barely touched, just exposing fresh bits of copper. Worth emphasising that antifould paints contain copper compounds designed to hold in the matrix and then break down into the poisonous versions at the surface. Coppercoat is simply (?) lumps of copper in a substrate of water based epoxy. The seawater converts the surface of exposed lumps into a poison, so if exhausted you can scour ioff a bit and expose fresh pure copper.
Rob.
Rob.
