Catweasel
heya,
I'm pondering getting a Rutland 504 for my Contessa and was wondering if any one here has this same set up (Contessa and 504) or similar.
FWIW it'll be my primary charger (am hoping to avoid marinas and the need to run the engine) and I'll be running down from the UK to Eastern Med.
I have considered solar but (and I am no expert) was put off by the issues obtaining sunlight (sail/raid/etc shadows and so on). I also considered, very briefly, a towed gen, but again was put off by the impact on speed (the boat's only good for about 5 knots as it is).
Thanks in advance for any responses
- Where did you mount it?
- Would you change the mounting point if you could?
- What problems did you encounter?
- Do you regret the purchase?
- Does it live up to your charging needs?
