Omatako
I just read a thread from Andyball regarding a fuse issue on busbars and I'm now con-fused.
A busbar serves the function of distributing electricity to several appliances/circuits at a place where it is convenient to locate. That is, a single cable runs from the battery/ies to the busbar and then circuits run from the busbar to the appliances.
If the cable from the battery were to be fused, it would need to be a fuse that carries enough current to power all the appliances fed by the busbar simultaneously. If not, the fuse (or breaker) would fail every time the max load condition is approached. So to fuse it to the thinnest wire will be real frustrating.
Rather ensure that the feeder cable is big enough to provide safe and adequate supply to the busbars and then ensure firstly that the busbars are located so that they cannot be accidentally bridged and secondly that all appliances are appropriately fused directly after the busbar.
My busbars are mounted on a vertical surface about 100mm apart, almost impossible to accidentally bridge them
Sorry to drag up old issues but I think this important
