kieron riley
Active Member
Has anyone ever found a cheaper supplier of a Yanmar 1gm10 con rod .
Extremely expensive!
You might find that in the case of the 1GM10, Yanmar are the only supplier.Indeed , but in my experience very few parts are made solely for one engine, or even engines made for one user
Unfortunately the 1GM is a one off design and although con rods are known to bend, usually as a result of a hydraulic lock following water entering the cylinder there is insufficient demand to justify anybody making "pirate" parts. Have you tried to straighten it? You might have luck for a used one from Cellar Marine in Cornwall.Indeed , but in my experience very few parts are made solely for one engine, or even engines made for one user
All Yanmar bits are too expensive!
I had to pay £400 quid for a four cylinder head gasket!
I know..............................£25 for my 4 cylinder...
See post #4. There is a recon one on Facebook.Crank, conrod, bearings,gaskets etc.. could it be cheaper to buy another used engine and save yourself a lot of time ?
And hey Yngmar have you by chance seen an alternative supplier of the crank shaft,(i think i may be a bit cheaky with thal last request) but i did try seaching on both Temu and ali Express but to no avail so what did you type in to find the con rod,
