computer prob
PhilF
18 Jun 2001
In a state
loads internet explorer and then freezes, says not responding
loads windows update and works, so internet connection ok
have run sophus and ad stopping software
reloaded ME 6
have deleted temp internet files and history
no firewall
loads MSN messaging., but wont access new mail, just freezes
any Ideas
Philf
<hr width=100% size=1>
Bit more info pls Phil..
Reloaded ME6? What's ME6?
Is this a new machine or when you say 'loads IE6' you meant start the app?
<hr width=100% size=1>my opinion is complete rubbish, probably.
its not new windows 2000 professional.
sorry meant Windows IE ver 6.
loads the front page of any internet site and then freezes, except MSN update site, works and downloads updates perfectly
No firewall! /forums/images/icons/shocked.gif
That's living dangerously to start with! Sounds like a DNS problem but shouldn't be if you are getting through to windows update. Could be any number of mailcious trojans if you have no firewall.
What type of connection do you have?
Have you done an up to date virus scan - preferably an online one like http://uk.trendmicro-europe.com/enterprise/products/housecall_launch.php
More info! /forums/images/icons/smile.gif
its my wifes computer, wireless networked via netgear router and d link adsl modem.
Was okay til yesterday, have searched for trojans and found and deleted some,
will try site suggested
I have a fire wall
OK usual question then.. what was your wife (or you!) doing immediately prior to this happenstance?
If it's a NAT router needn't worry too much about firewall being on/off.
Presume you've tried a restart?
Couple of things bother me. Firstly, you may be seeing cached 'front' pages, and secondly, does the MS update seem to do an update every time you ask it to? I'd only expect to see it do it once.
def not cached pages.
she was using it for e mails, no downloads she said
tried restart and have visited online virus checker as mentioned, but cant click to start
A lot of the online av products have failed for me too. Try <A target="_blank" HREF=http://www.grisoft.com/us/us_dwnl_free.php>http://www.grisoft.com/us/us_dwnl_free.php</A> and download the free version, do the updates and then do a full scan.
But this doesn't really sound like a virus. You mentioned your firewall, which one are you using?
the firewall does not affect Helens computer.
The problem is, once logged onto the Internet
Any site opens , but I have now discovered that if I wait, a mouse click will work but takes 2-3 minutes to action, then next click the same. Only on the internet, computer works fine otherwise.
I did the full scan and no virus found, I have defragged and have loads of memory,
Thanks for interest
Philf
Have you looked at 'processes' in task manager? (Right click task bar to get to it). Click processes, then on the cpu heading. At the top or bottom something will be using the highest %age. Do the same for 'mem usage'. Watch what happens to the processes when you click to go to a new web address.
If something suddenly leaps up, what is it?
Phil
Does the entire computer freeze or is it just IE that stops responding? Does the CAPS LED flick on and off when you press the CAPS LOCK key? Will it reboot with CTRL ALT DEL or do you have to power it off? If you CTRL ALT DEL, does it it tell you it is IE that is not responding? If so, if you kill IE, does the computer run normally after that? Does it lock again if you start IE again?
hello again. Its only in IE.
reboots okay with ctr alt dlt and yes it says IE is not responding.
C0mputer works perfectly except in IE.
First page, any page, loads and then freezes for 2-3 minutes on first click to move on and so forth.
Have used Adaware and spy catcher and now loaded Zone alarm.
Have cleared Temp Internet folder.
Philf
Is your wifes computer only one on wireless network? problem could be with accessing network, would check is working ok. Also check connection settings in IE.
You may need to uninstall IE first before re-installing.
You haven't downloaded a new driver which might be causing a problem? Possibly go to netgear site and check for latest drivers( obviously would need a different computer to check if your wifes not working)
she has no problem accessing any site on the internet, its just the screen freezes on any click on any page.
There is another computer on the nertwork, this one , and it works fine,
i'm sure its a virus, but cant remove it
please what is scagent.exe
it is in the win directory
I have loaded netscape and it worls if I dont allow scagen to load
it seems to seen me to a spoof netscape site with porn and stuff
