Roberto
I was on a night crossing last week when I saw a red over white light on my starboard side, the bearing slowly decreasing so we were in a crossing situation.
At first I thought it was a fishing vessel, a bit far so the red and green sidelights might not be visible. I modified my course to starboard, to let it pass on my port side.
Given how more rapidly the bearing was decreasing, I guessed it was nearer than I thought, but the sidelights were still not visible.
A few minutes after it crossed my bow, the red light disappeared and there was only the white on.
My thoughts: basically, it was not a fishing boat but something else. The only possibility I have found is a sailboat with a tricolour on, plus the masthead light below (flat calm so quite possible).
Is this a possible, and especially a legally correct way of using the nav lights?
I have spent many nights sailing in busy areas but this is the first time I saw this configuration.
I think in the colregs it is not stated that the steaming light must be above the sidelights (true?), although being denominated white mastlight I personally would think so. If this is the case then that sailboat was correct.
If it is so, then why bother having one tricolour (plain sailing)+ masthead white light + additional red and green sidelights on deck as many boats have? The two deck sidelights seem redundant..
thanks
thanks
