Lodesman77
Do you have them all on in the cabin at once? That would be nearly 3kW...
Four ideas/observations:
3) A liveaboard friend built an impressive heater contraption to go on his gas cooker. It is an upturned brass or copper pan that sits on the burner, out of that comes a tube about 4" dia other end of which pokes out of a similar sized opening port to exhaust the fumes/moisture outside, and a series of brass or copper plates with holes in the middle the size of the tube fixed (brazed?) onto it to conduct the heat away from the tube (to the extent it is virtually cold at the upper end before it gets to the opening port. Gives off a goodly amount of heat without fumes.
4) Combine any or all of the above with a cuddlesome shipmate!
