Climbing rope for halyards?
Rivers & creeks
23 Nov 2004
Norfolk
I've been given some new climbing rope and I need to fit a new main halyard. The boat is a cruising 35 footer, is climbing rope too stretchy or is it ok? Thanks.
Internally a climbing rope has the fibres laid out in parallell to make it stretchy.
Rope for halyards has the fibres pleated to make it non-stretchy and it is then pre-stretched to make it even better.
I suspect if it is tensioned it will seem fine, however what will happen is that it will suddenly go bang and break. Basically climbing rope is not designed to be kept under tension! How do I know .. I tried it a while ago ;-)
static or dynamic
There are two basic types of climbing ropes.
Dynamic rope EN 892: dynamic elongation up to 40% 80kg mass
Static rope EN 1891: less than 5% elongation 50-150kg mass
Some high tech access lines are dyneema / vectran core for ultra low stretch.
It would be impossable to say about its use as a halyard without knowing exactly what rope it is?
