ducked
Not recommending this, but 4WIW, which yáll can decide for yourselves, I seem to have done OK using polythene sheet on threads as a nyloc substitute.Shackles are 'different' and split pins or rings don't come into the equation - so Thinwater's mention and my detail is a bit of thread drift. For shackles, anchor shackles, I'd be happy with Loctite - but Loctite really is not a replacement for a split pin - different requirement. Loctite can replace wire (or used as well as wire)
For a discussion on split pins/rings then a simple bolt and nut comes into the equation - with the nut being a Nyloc nut or secured with Loctite.
Jonathan
On, for example, a lugnut, the (optionally greased) polythene comes off like a thread formed shed snakeskin.
This started as antiseize and threadlock substitute (both of which I found very hard to find in Taiwan) on cars and motorcycles. Havn't so far done it in a marine context, but it might have utility as a barrier between disimmilar metals in rigging.
