capnsensible
Imagine, for a moment that he may actually go elsewhere.
The OP is moving from a swinger into a tight marina berth,with a longish keel, so lines made-up to the correct length make berthing & leaving easier
Imagine, for a moment, that you have actually gone somewhere else.
The OP is moving to a berth near me, Hence the reply THATS how it helps
Its a shame that we cant all be perfect isnt itBut he did not ask about a berth or about whether he should have permanent lines, nor what you do. How does him moving to a berth near you matter?
He specifically asked about a slip knot. And you did not respond, but gave useless information about how you moor your boat.
What I'm looking for is a cunning knot (or similar) by which a mooring rope on a pontoon cleat could be quickly and confidently released by an operator at the boat end of the rope.
Such a knot was described on a thread on here a year or three ago. Despite much searching I can't find it again. (It was the sort of thing you look at and think 'Of course! Why didn't I think of that? It's so obvious I'll certainly remember it'. But I don't!)
(I do have one of those proprietary quick release mooring hook gadgets, but it doesn't suit some sizes/shapes of cleat, etc.)
I have an 'interesting' close quarters/long keel/single handed situation to address, where I need to be able to leave a longish line attached to the end of the finger pontoon as I depart, in order to turn the boat sharply as soon as it is clear of the finger and neighbouring boat, then release and recover the line smartly as soon as the boat is at right angles to the finger. Having the line release too soon, or fail to release when required, would be highly stressful and quite possibly expensive!![]()
Here's a possible solution for you. I love this guy's presentation, a no-nonsense video of how to make a quick release knot. http://www.youtube.com/watch?v=6Nxu-jS9TSc&list=FLvo1BuibEUZOCUHZOkqW3-A&index=13
I use this one all the time. Also good for tying up horses, haynets and when tying up our rhib single handed.
Reminds me of the time I saw a yacht leave a catway in St Vaast leaving behind a length of rope attached to a cleat. "Ah ha" I said to myself "if they don't want that, I'll have it!"I have used the following method to get out of a visitors berth but should also work for repeated use in a regular berth.
Use your tatty-est yet strong piece of nylon or polyester line and at the appropriate time release it from the boat end and leave it behind to sink out of the way. I keep such a piece of line that i don't mind loosing if it means i can get out of a tight spot singlehanded without damage. This is the the most foolproof method i have found. In your case, after you return to your berth just retrieve the line for next time you leave. If you use a good looking piece of line it may not be there on your return.
The catway was one of those horrible narow wobbly ones and, as I crawled gingerly backwards clutching my prize, a voice behind said "Cheers mate! We were having a problem leaving the berth so we let the line go and moved round to the fuel pontoon and now I've come back for it"
Use your . . . . line and at the appropriate time release it from the boat end and leave it behind to sink out of the way.
The yardies use long wooden boat hooks to move some boats about the marina ( it saves using engines ) that might be an option for you too.I did wonder about doing something like that (it's my new home berth, so the line wouldn't be lost after use), but it's a crowded situation, and I could become very unpopular if the line didn't sink fast/far enough, or got churned up from the bottom during someones manouevrings. I thought a suitable length of light chain might be preferable, with a short bit of rope on the boat end for cleating off and releasing.
Either rope or chain would end up very muddy/mucky on the bottom (and probably so would I every time I retrieved it:disgust, so I might try the quick relase knot first.
The idea of leaving an old line behind, if the situation demands it, when visiting somewhere else is a good one, though, so I'll hang on to some of the scraggier ropes I was planning to clear out.
I haven't understood why a long line set to slip wouldn't suffice?
It strikes me that any solution to this conundrum, other than leaving a fixed line behind, requires a line twice the length required. That's no matter whether you use a release knot, bit of broom handle or a simple slip line. For preference, I'd go for the slip line as it's the simplest solution and least prone to getting jammed.
Question: What type of rope does the team think would slip easiest and be least likely to kink and get itself caught up? Braid on braid?
