Ianthediver
Active Member
Could you please help and advise me if the pro clean or simalar works well with cleaning the engine and heat exchanger or if it is better to take it all apart and do it manualy? Ian Parish (Fandangle shotley)
I would take it apart, it’s simple enough and as a result in my case the engine is running much cooler. Could be something to do with the 4 impeller vanes I found. I only knew about 2 of them….Could you please help and advise me if the pro clean or simalar works well with cleaning the engine and heat exchanger or if it is better to take it all apart and do it manualy? Ian Parish (Fandangle shotley)
Thank you the boat is 1999 and I will mark the end caps before taking them off and buy new seals.do you mean Md2030
if so fairly simple main thing is making sure endcaps (rubber) are in the correct place but they may require replacing
if it’s 2002/3 make sure the covers go according to original mark them before dismantlong
Also cover seals if not 2000 series does not apply
I suspect that you are confusing my reply regarding Volvo engine designationsThank you the boat is 1999 and I will mark the end caps before taking them off and buy new seals.
I's flush it with Rydelyme, does the whole system, not just the heat exchanger.
[/QU
