Cleaning my bottom - what tools?
Captain Crisp
1 Mar 2015
Hi - I'm hoping to clean my bottom next week on the Brightlingsea scrubbing posts. What tools do the panel recommend? Bottom is looking very hairy... launched in May...
Thanks!
Crisp
Martin_J
19 Apr 2006
Portsmouth, UK
I used to find the easiest way to do it was to jump in and scrub around the receding waterline as the tide dropped.
By the time you've gone around the boat once, the tide will have dropped another few inches.
By the time the water is just around your ankles the boat will be clean.
Use something like a big pan scrub (handle not needed). Doing it this way also saves trying to get water later to wash bits down that are by now already dry and hard.
Last time I did it there was an elderly couple in the next set of piles. We went around their waterline as the tide dropped as well... and we were invited to drinks on board with them later as a thank you!
B27
26 Jul 2023
I have three tools on sticks:
A plastic scraper
A flat bit of wood covered in astroturf, with a layer of close cell foam camping mat in between
A couple of wet'n'dry sanding sponges on a flat bit of wood.
Other scrapers may be needed for barnacles.
BobnLesley
1 Dec 2005
Aground in Yorkshire awaiting a very high tide
Thanks!
Crisp
As with the anti-fouling, a Gentleman should allow his lady wife to select for herself what tools she'd prefer to use.
jwilson
22 Jul 2006
OK... my fault for being puerile... but, seriously, what do I use to get the weed off?
Seriously, a fish slice is really quite good. As it is designed to go into pans, it is not as sharp-corner-edged as most paint scrapers. Or use a paint scraper but file/grind round the sharp corners a bit. All this assumes you can't use a pressure washer which is the modern option (and much more efficient).
The various "plastic scrubbie pads" are fine until you get much weed: then they clog up and you spend more time cleaning them than scrubbing.
