Cleaning fingers
In the absence of any White Spirit, what common household substance would you use to get Varnish off your fingers? I've just been varnishing my floorboards, made the usual (for me) mess on my hands and now realised I haven't got any White Spirit at home.
Thanks in advance
Richard
It was a serious question!. No laughing matter; not to me anyway:)
Richard
P.S. How do I get varnish off the keyboard?
Laurel's solution to getting fingers clean is to make bread. Nothing like it. The dough is better than anything, and if you don't fancy the bread, use it for poisoning the seagulls.
William Cooper
Lateral thinking
Mmm - not sure about eating it!
Thanks for all the suggestions; I have solved the problem a slightky different way. I popped next door and borrowed some White Spirit from the neighbours.
Cheers
Richard
lezgar
15 Aug 2001
When I paint or repair the engine I always use gloves (surgeon type, you can buy in Tesco or DIY stores). This avoid to dirt my hands and use poisons for clean after.
longjohnsilver
30 May 2001
WD 40
Well I just drank a pint of the stuff by mistake, thought it was a can of Old Speckled Hen and boy do I feel well oiled............
<BG>
Just tried that. Works much better; hands are cleaner and the finish is better.
Thanks for the idea
Richard
robp
Now this is abslolutely true!
Years and years ago, I once read a write up on WD-40. It seriously said "there are hundreds of uses for WD-40, you can even put it in your tea for an efficaceous effect" - spelling? What it was suppose to do I can't remember. I can only imagine the result though and the eye of a needle comes to mind!
Did it taste better than Speckled Hen??
AndrewB
7 Jun 2001
Dover/Corfu
Don\'t. Remember the Fairy commercials?
Only Bill Cooper's suggestion is sensible, that or mild soap and water.
Use any solvent repeatedly, even White Spirit, and eventually your hands will roughen up permanently. Same goes for detergents. Good for DIY ... rotten for sex. Conventional varnish may be sticky for a day or two, but it won't damage your skin.
Wear your Marigolds next time.
