AllanG
What do you use for cleaning the plastic windows in your cockpit cover?
Thanks in advance!
Allan
Thanks in advance!
Allan
Gave my 4 yr old covers to my local canopy maker £100 later I had 3 new windows,
Good as the day she arrived
sounds OK, but must get expensive every time you want them clean...![]()
for plastic windows personally I would not use a "glass cleaner", fast glass great on glass, but acrylic needs different care IMHO.
I would use Mer Polish if dirty and marked (with 2 micro fibre cloths, 1 to apply & 1 to remove, apply with circular motion, allow to dry and buff off, obviously make sure you don't get on canopy fabric)
http://www.merproducts.com/Products/Product/20
This can restore old acrylic windows to really good order.
as a maintenance clean I then just use Autosmart Stardust Eclat, spray on & polish and buff, be generous if dirty, this has no silicon and so is idea on acrylic ;
http://www.ebay.co.uk/itm/Autosmart-Stardust-Eclat-Car-Instant-Polish-Dressing-BN-/40024495684
I have found that fast glass is one of the only "glass cleaners" that works well on the softer, plastic windows.
It will rid the surface of the most stubborn contaminates and leave a perfect streak free finish.
Most 'glass cleaners' are not that great on the softer, flexible material, some are even not safe for the surface, so you are correct to give it some caution.
Auto glym fast glass is different.
Used for years with correct results and is the only glass cleaner I carry/use on a daily basis and I have got through quite a few brands, 3M, Megiuars, even Nanolex do not compare with the quick streak free results the AG provides.
If we are talking restoration, then it is a different ball game.
For restoration of flexible windows, scratch / blooming removal etc, I would go for Meguiars Plast RX and polish via machine, the only reason I would not use Farecla's Mer polish is because it contains 10% petroleum that may react some time after application, it will lose it's flexibility and age faster in the sun.
