cleaning blocking diode connections
oldjohnnyb
18 Sep 2001
I want to clean the stud bolt connections on a blocking diode assembly. They are badly corroded and i'm not sure the nuts will come off. I am proposing to use "Servicol 10". I am concerned that solvent will penitrate the moulding in which the rectifiers are sealed. Has anybody any thoughts. I am reluctant to use "Plusgas" but again any thoughts.
John
ccscott49
7 Sep 2001
What type of corrosion? Rust? a little plus gas should help that and with careful use so should any other of the same type, if its verdigrise type (copper) a little hot water should help, be very careful, as they could break. If you are careful the plus gas etc, shouldnt damage bthe stuff sealing the box.
charles_reed
29 Jun 2001
Splitting diode connections
In fact a major problem if you have any big (>30amp) currents flowing.
You'll find they're cadmium plated steel.
I now clean mine every year as part of spring fit-out, the ferric oxide acts as a major resistence and causes local overheating.
I've not used WD40 - a little drop of diesel is cheaper and just as effective - and no the insulation substarte doesn't appear to be affected by common solvents.
Clean with phosphoric acid - neutralise and coat with silicone/teflon grease or better copper grease (as is used for anti-squeak in automotive brake assemblies).
Watch out for local damage to the insulation material when you unscrew them !!
Good luck
