Quandary
This is the next Pot & Kettle question.
Stephen's Longbow has a custom made moulded GRP canopy over the main hatch, it has windows in the front and sides which appear to have streaks of a cloudy white coating on the outside surface, they are approx 6mm. rigid flat acrylic, probably perspex? I was hoping to clean them using 1200-2000 grade wet and dry, used wet and soapy, followed by rubbing compound (T-cut) but before I start, can anyone advise a better method. Scouring pads and some sort of cleaning liquid perhaps?
The coating seems only to be on the outside surface and there is no crazing but I have some concern that since the doghouse was moulded locally, the window may be a softer type of plastic or one that has been vulnerable to weather.
