Boo2
nothing at all worth seeing on the East Coast
It's a bit flat though ?
Boo2
Boo2
hmm 1600 miles in 9 weeks, while cruising and sight seeing ? That's going to miss a lot of exciting and interesting places.
If I had 8 or 9 weeks to sail in the UK I would go from Holland to Inverness, through the canal, up the West Coast of Scotland, round Cape Wrath to Orkney then back fairly directly down the North Sea to Holland. Just a thought but those are the best bits. Shetland is worth a visit too.
If you go clockwise round, you can spend a large amount of time beating down the English Channel into the prevailing winds before you reach The Scilly Isles before turning north up the Irish Sea. This is a long sea path 550kms (300nm).
you are so correct
got it in one
not for the depth challenged sailors anyway
I went anti-clockwise.
IMO, the clockwise route at the start (assuming you are coming from Holland) is more likely to present adverse conditions. I was once stuck in Ramsgate for several weeks trying to head west.
When you emerge at Fort William, even if you face SW winds, you can cut an interesting route via Bangor (NI), IOM, Conway or Dublin, Kilmore Quay and on to the West Country.
With luck you will have a pleasant run down the English Channel and home.
Round Britain via the canals is like running a 10km and calling it a marathon. So my suggestion, for what it's worth, is head northwest from the Netherlands and hit the English coast up around Blyth, continue north via the Forth, then up to the Caledonian Canal, through that then turn right up the Sound of Mull and then meander north up the west coast of Scotland, then it's a lot of choices up to Orkney and/or Shetland. Load up with duty-free booze and head east to Norway, down the coast, through the Skagerrak and Kattegat, down the Danish Coast, through the Kiel Canal and home.
Lots of advantages in that route amongst which is cost - basically the avoidance of hideously overpriced marinas; the purity of the English language - once you are past Fraserburgh the purity of the language is a joy, especially in Norway and Denmark, a vast improvement on the strange south of England whine; lots of choice of places to go and safe harbours; culture - there is some unlike the south coast route; and lastly avoidance of the Olympics.
you will have the Ellenites after you with talk of marathons and 10ks
Dylan
I am based on the South Coast and my plan is to go anti-clockwise because it will mean getting to the Scillies at the end of summer when the weather and water will be at their warmest.
If I was starting from the Netherlands though, I might be inclined to go the other direction because if I ran out of time then cutting the East Coast of England would be possible and less of a hardship in terms of missed attractions.
Just my opinion,
Boo2
Prevailing winds are one thing, actual winds are another.
I think Sam Steele summed it up nicely when she met someone going anti-clockwise when they were going around clockwise. Both though the other direction would have been better!
There is no right answer.
Forgot to say...by missing out north of the caley, and from Mull north on the west coast you are missing out on IMO some of the best cruising in the world
. . . . And uhmm ... a stupid question from a Dutchman: north of the caley, where is that? Apparently I should not miss that.
Not stupid at all. "The Caley" is a slang term for the Caledonian Canal (which cost money) to use and runs from the NE towards the SW from Inverness down towards Oban on the west coast.
I hope this helps?
. . . . but I suppose Loch Ness is still there ;-)
