jaminb
I am worried now. I used those heat shrink solder connectors to rejoin the fine data wires in the headlining after I cut to get the mast down. I intended to use Wago's but couldn't get them to clamp on the fine wires, plus I don't think there would be room in the void for all the connections.
I used an electric heat gun to warm up the connector, I could see the solder fuse into the twisted join before the heat shrink started to shrivel. I couldn't pull them apart at the time but better check to see if the solder has crept and they are now falling apart!
