jfm
Dockhead,I'm increasingly disagreeing with you in your last few posts.This is generally reasonable, however --
1. The judge's obiter dictum in Windsor-Roanoke about not taking course and speed literally, has NOT been accepted as a general rule, and has not been extended to sailboats tacking up a channel (or to ships' adjusting compasses, or to anything else for that matter), so take it with a grain of salt. As a matter of law, this is anything but "case closed" -- it is one argument you can make, but it's not binding precedent if it's not on point, and has not been generally accepted as a rule with broad application.
2. It is NEVER reasonable, as the stand-on vessel, to assume that the give-way vessel is taking adequate measures to prevent a collision. You are specifically obligated to keep a sharp watch and take action when necessary. The idea that you can tack willy-nilly up a channel without regard to developing collision situations is wrong on several different levels. You must see that you have room to tack, before executing the tack -- you must not just tack and let the mobo worry about it, including breaking his stern gear or whatever. This is a general, and important, principle of collision avoidance, which is often neglected, as it is very different from how it's done in land, in traffic.
What is your basis for saying the quoted part of Lord Alverstone's speech is merely obiter? If the claim from the other ship was that Roanoke disobeyed 17(a)(i) then surely that part of the speech is ratio. The eminent Cockcroft even quotes it in the bit of his book dealing with rule 17: why would he bother quoting obiter? I've ordered the full case and it turns out that it is ratio I'll be back on your case, somewhat firmly(!). In the same vein, you advance no argument why Lord A's rule isn't applicable to sailboats tacking in a channel, despite the fact that at least prima facie it is. One looks look for principles in case law; there's no need for identical facts, so it is "on point". Your reference to the later compass adjusting collision case is fundamentally flawed - you should check which way that particular gun is pointing before repeatedly pulling the trigger; it supports my position and Bedouin's not yours
Ref your para 2, you ought to put the spade down. First, the reference to willy nilly is entirely a strawman that you have invented. Second, there is nothing in Colregs requiring any sailboat to be sure of room to tack when 17(a)(i) applies to it, nor is there anything in Colregs saying the stand on vessel should worry about the give-way's stern gear. You are letting your mind drift onto what you think is right, as distinct from what Colregs actually say. Great that you care about someone else's' stern gear, but someone who doesn't isn't thereby in breach of Colregs. (FWIW, I would proffer the thought that anyone wanting consideration for his own stern gear is more likely to get it if he has clean hands, unlike Mr Dashcam Tooter!)
