KellysEye
I do wonder whether these had anything to do with it:
1.12.2 Groundings, damage and repairs August 2007 - grounding During Cowes Week in August 2007 Cheeki Rafiki suffered what was described as a ‘light grounding’ in Stanswood Bay, in The Solent. It was subsequently inspected by a GRP repairer who had the vessel lifted out of the water and temporarily rested it on its keel to enable inspection for signs of hull deflection. The matrix was then hammer tested in an attempt to identify detached areas. Repairs to the vessel were completed in September 2007.
6 Loose equipment. Equipment which was not permanently attached to the vessel or part of the vessel’s structure and could be removed from the vessel. This included safety equipment such as liferaft, EPIRB etc.
27
The repair invoice detailed the following: ‘Remove floor boards and pipe work in way of damaged areas. Cut flanges off six bays, grind back hull, laminate and sides of structural floors. Bond structural floor to hull with GRP, lightly rub down and apply wax gel. Drill off limber holes, refit pipes and floors. Clean vessel. Lift plate washers and re bed’. Cheeki Rafiki’s keel was not removed to carry out these repairs.
October 2007 – keel dressed In October 2007, Cheeki Rafiki’s keel was dressed. It is not known how or when the damage that required the repair occurred. The invoice detailed the following:
‘Dress out damage to lead keel. Fill and fair with epoxy filler. Apply epoxy primer and two coats of patch antifouling.’ It was reported that an inspection of the vessel and its matrix had probably been completed during the time the vessel was under repair, with no other defects detected. However, no documentary evidence could be found to support this. 2010 Round the Island race – grounding During the 2010 Round the Island race, Cheeki Rafiki reportedly grounded at St Catherine’s Point on the Isle of Wight, after it ‘dropped on to the ground’ when in the trough of a wave.
Another report:
The court also heard how the vessel, which had grounded three times in three years, had an undetected fault with the keel bolts and that some of the bolts had been broken “for some time” before the yacht left the UK.
“In accordance with Section 100 of The Merchant Shipping Act, Douglas Innes, the yacht’s manager, had a legal responsibility to maintain the Cheeki Rafiki in a seaworthy condition, especially when considering her frequent groundings,” he adds. “And because of sloppy oversight, the coding surveyor failed to carry out a comprehensive survey when the Cheeki Rafiki was inspected for MCA Coding.”
27
Another report:
