RIN
I hope to service my KAD32's this weekend as the boat will shortly be coming out of the water. This will be the first time I have done this so would be grateful of any omissions, advice or observations
Here's my list:
1) warm up engines
2) remove oil by via dipstick hole
3) replace oil filters
4) fill up with new oil (can anyone recommend a cheaper substitute for volvo oil? SAE 15W/40)
then either
5) replace fine diesel filters on the engines, will I need to bleed the high pressure nozzles or is it just a case of bleeding the fuel pump?
OR
6) replace fine filters and the Racor course filters. The course filters were replaced in May 06 . Do I need to replace them every year? (they are quite expensive) and then bleed the entire fuel system up to the HP nozzles
7) check oil in the compressors
8) fresh water cooling system - replace the coolant - do I need to use the volvo inhibitor or is there something cheaper as good
9) run engines to check all ok
Plan then is to do the raw water bits when the boat is out of the water. Do I need to replace the impellers every year?
Also are there any engine anodes on the KAD32 that need replacing?
Finally will this cheap oil extractor work? oil extractor Is it man enough for the job and is there any danger the tube stuck down the dipstick hole will melt if the engines are hot? Probably a dumb question but then I have only ever changed engine oil in my cars via the sump plug
Thanks in advance for your comments
Richard
Here's my list:
1) warm up engines
then either
OR
Richard
