Sticky Fingers
Had 100% success with it in my own use case. New tools including my cheapo Titan drill driver are indeed Lithium.
This is definitely true. I won't buy cheap drill bits unless it's something special for a specific, one-off jobI think the quality of the drill bits is at least as important as the drill.
Not had a problem with either Bosch drill. The one listed in my reply I have on the boat and the one at home is an older version of this https://www.amazon.co.uk/Bosch-Cordless-UniversalImpact-Batteries-Carrying/dp/B09X5YBF6G/ Both have 2 speed gearbox and multiple torque settings.Here's a question- a friend just kindly loaded me a Bosch drill to do a job, and it was frankly useless compared to my (genuine) Makita. The slowest available speed was far too fast for drilling metal or driving screws. Recipe for an instant snapped drill bit.
Is this a common problem with cheaper drill/drivers? Maybe it was just that particular model?
That just reminded me of buying a B&D drill off the Exchange and Mart a long time ago. Came with a range of drills. Rubbish steel and one was actually left handed!So, I'm almost certainly going to regret this, but I've ponied up £24 on eBay for a Makita compatible drill/driver with battery and charger. Even comes with a set of bits and drills which are likely made of a tin-cheese alloy.
I'm used to the real thing so it will be interesting to see just how bad this is...
The one I used yesterday had a two speed gearbox and multiple torque settings. But the slowest speed was still, at a guess, hundreds of rpm.Not had a problem with either Bosch drill. The one listed in my reply I have on the boat and the one at home is an older version of this https://www.amazon.co.uk/Bosch-Cordless-UniversalImpact-Batteries-Carrying/dp/B09X5YBF6G/ Both have 2 speed gearbox and multiple torque settings.
Even my ancient 14.4V 1.2 Ahr Bosch "Professional" (Blue) which I have had for over 20 years has a torque setting allied to the speed setting that ensures that screws can be properly seated and not over driven. I can't remember using it on metal but it has variable speed by trigger pressure so it's quite a reasonable drill driver and even has hammer action but by modern standards it's an average to poor driver and can't compare to my 18V 5 Ahr Makita which has virtually replaced my corded drill, it has all the options of the old Bosch however it cost about €350.Here's a question- a friend just kindly loaded me a Bosch drill to do a job, and it was frankly useless compared to my (genuine) Makita. The slowest available speed was far too fast for drilling metal or driving screws. Recipe for an instant snapped drill bit.
Certainly is a budget brand!Not a budget brand though.
As others have said, he trigger is speed control on low range (0-450 rpm)Not had a problem with either Bosch drill. The one listed in my reply I have on the boat and the one at home is an older version of this https://www.amazon.co.uk/Bosch-Cordless-UniversalImpact-Batteries-Carrying/dp/B09X5YBF6G/ Both have 2 speed gearbox and multiple torque settings.
I've just looked it up! You're right; but that's not the Wolf brand I remember. Apologies for any confusion.Certainly is a budget brand!
I try and avoid drilling stalls but when I have to its a hand drill and sharp bit.and also very handy when drilling metal.
