AngusMcDoon
One technical question. Is the power consumption low enough for the finished display work off internal batteries?
No. That size display requires external power, especially with the backlight on.
This would be worth a visit: http://mail.colnedata.co.uk/events/event.asp?CONTSUPREF=SOUTHELEC13
Would it be worth having some sort of poll to see about how many mast displays may be required. It would give me and anyone else, looking to source a case some idea of the possible volume. I think I can find a home for four.
Good idea................no idea how you create a poll though !!
What about this company, I live local so could look into it further.
http://www.evatron.com/index-pag-family-cid-2-l-2.html
Those are no good as they have cable gland knock outs which are purposefully very weak. Although waterproof they are not designed for somewhere like a mast where a small knock even from a rope might open up a 1" hole in the box.
OK so how about this, an aluminium or stainless sleeve box is made with the fixing bracket on the back and then one of the plastic boxes slides in.
This would give the mechanical protection as well as the waterproof protection.
this is what I probably proposed in one of the initial posts. Just a simple ip 65 rated cheap enclosure with transparent lid. Then as anyway a mast bracket will be needed to mount it, attach the enclosure behing the aluminium, make a matching hole only big enough so that lcd display can be seen. The box would essentially be hidden from view, just the numbers from the display visible. With some basic metal work skills should come up pretty good looking solution?
