greenalien
As others have already pointed out, visibility of the screens is a major issue, most colour screens are invisible in sunlight, as any mobile phone owner knows! The Garmin GMI-10 is the exception that proves the rule - I bet the special coated glass on the front of these costs a lot! Maybe a cheaper option would be to use an array of LEDs - cheap, bright and easy to see. You could use 7-segment devices that are already set up to display numbers, these are already available in large sizes - e.g. http://proto-pic.co.uk/7-segment-red-6-5-display/ - if this is too big, how about these - http://www.ebay.co.uk/itm/3-inch-7segment-Blue-LED-display-common-anode-2pcs-/310422336744 - or you could build a bigger array using discreet devices. This would be great for wind angles, for example, where you could have a circular display, using RGB LEDs, varying the colours as the wind direction changes - you could even show true and apparent wind on the same display, in different colours.
