CKG
Those are bottom end estimates and assume mostly second hand items. Engine and installation (new) £7-8k as you usually find most of the ancilliaries need changing because they are knackered or incompatible. Sails new and basic £2500. Secondhand sails are relatively cheap usually because they are no good or won't fit. Rigging wire and terminals £1000+. electronics (basic) £1000 up to £8k for full set and autopilot. Rewire to good standard with decent battery banks £1000-1500 for materials. Reupholstery £2-3k professional £4-500 materials. Cooker and modern gas system £700 materials. Heating and hot water £3k materials. Electric windlass and modern anchor £1500
And so it goes on. You can see how large sums of money can disappear very quickly, but it does give you an idea of what to pay attention to when buying to minimise subsequent big expenditure. Of course some of those items are discretionary and you can save by waiting until a bargain or used bit turns up.
Fitting out a boat for living on and travelling long distances is of a different order from using a boat for weekends. You wear things out so everything needs to be as good as you can get. It is an advantage living on the boat as you can fix and change things as you go along but the danger is that it becomes fixing things most of the time and from time to time having enough working properly to move on!
Thanks for pointing all this out to me. Engine installation: With a good mechanic/friend an old diesel engine could be reconditioned and would be reliable at a fraction of the cost of a new one. Y/N?
Decent used sails that fit can be found with a bit of effort searching. Y/N?
Why would the re-wire be so extortionate? Even high quality deep cycle leisure batteries are relatively well priced these days. 12 volt wiring can be bought for £12-£20 for 100 metres even if you're not in the trade.
Re-upholstery could be done for a fraction of the cost of £2-3k regardless of whether it's on a boat or not.
Cooker: double burner £50 or less.
Heating: Diesel heater £170.
Hot water: Heated on £50 double burner or solar shower (£10).
Electric windlass: nice but not necessary.
Quality Rocna anchor: £400.
Surely, like a house, a boat will deteriorate faster if not constantly lived in/on. Maintenance is part and parcel of any dwelling.
I hope I'm not sounding dismissive as I really appreciate the time you took to inform me of all this potential expenditure.
