Sinnot
I was in a chandlers here in Croatia and saw Cobra handheld VHF radio and though about maybe getting a 2nd handheld VHF as a backup and as in all things that are in Marine Chandlers it was expensive (about 275 euros), so figured I'd check how much it was on Amazon and order it there as I'd have it in a few days at a much lower cost.
When searching Amazon I came across a Baofeng Radio which covered the Marine band for under 30 Euros. And with a programming cable and some free software "Chirp" I was able to configure the radio to receive all the channels, define what power and configure all the channels that use duplex etc.
The Software already has the marine channels loaded, so it was a very quick procedure to configure the radio to have all the marine VHF channels. It took me about 30 minutes to download the USB drivers and get everything set up and uploaded to the radio.
On board I also have a number of walkie talkies so the crew can stay in touch when they leave the boat. I was also able to program into it these frequencies, plus anything else that may be out there. If you are in the US, you can also program NOAA channels into it.
So the downside, is that its not obviously as high end as a dedicated marine VHF, it doesn't float, is not water proof etc (in 5 years I've never dropped my VHF into the sea - so this is not a priority for me). But it performs very well as a radio and at under 30 euros its at a price point where I'm not worried if it gets damaged. It may also transmit too much power if you program in FRS, PMR, GMRS channels but each country has its own frequencies and rules, so check that out first. If you get a HAM license (easy to get one in the US - Technician License) you can also use a lot more frequencies
The cheapest one is about £22.95. Baofeng UV-5RE -
From an design point of view. I prefer the Baofeng Pofung GT3 Mark II It costs a bit more £32.99
The main parts of this post were taken from a blog post I wrote today - http://www.thingzen.com/#!Cheap-Marine-VHF-handheld-Radio/xee9z/575d3b390cf2cc77ac002df7
