Hurricane
Let me check if I got this right.
What you are saying is that if in a crossing there's some current pushing the boat to port first and to stbd later (or the other way round), the actual distance through water is shorter if you let the boat drift to port/stbd (or vv), rather than follow a straight COG, as any a/p would do on track mode, correct?
If so, I fully understand the principle, but I struggle with the 10Nm difference.
I mean, I had a look at my maps, and found that we're talking of an 80Nm or so crossing.
Therefore, it takes roughly a 40Nm drifting, to make the crossing 10Nm longer.
Now, let's consider a theoretical best case of current on one side for the first half, and exactly the same current on the opposite side for the second half - i.e., 20Nm drifting to port/stbd on the first half, and 20Nm to stbd/port on the second half, which is exactly what you need to reach the desired destination without "fighting the current".
BUT, at a typical P speed of 20Kts, it only takes 2 hours to make 40kts.
So, in order to drift sideways by 20Nm in the same timeframe, the current should be 10Kts, no less!
Btw, I'm well aware that the exact numbers are not so round, but I did the math by heart, without caring about trigonometry, just because your 10Nm made me curious. Unless there's some other major factor which I missed, these numbers should be good enough for a rough consistency check.
Back to the point, can that REALLY happen, in the Channel?
Is it possible to have not only 10Kts currents (which already sounds unbelievable, to my admittedly ignorant ears), but also flowing in the opposite directions half way, reversing the direction completely in the blink of an eye, during such a relatively short crossing?
That sounds like a nightmare even for ships!![]()
I think Mark's comment carries more weight for sailing yachts where they can "lee bow" the tide thus getting more apparent wind etc.
But that isn't the case for motorboats and I tend to agree that Mark's point is a bit exaggerated.
Ant to do what he suggests require continual adjustment of the course - IMO not a good idea for beginners.
