Chart plotter scale
pcatterall
2 Aug 2004
I recently posted that our garmin plotter.seized when attempting to change scale . Lotd of fiddling.about .indicated that the contacts on.the card was the problem it still.freezes after about 10 scale changes.so we don't want to.change scale at a tricky moment! Is there a way to.clean the contacts inside the unit?
I suspect it depends if the switches are 'clicky' microswitches or the spongy rubber contact patch. I regularly have to clean the spongy ones on the TV remote with alcohol. I've never had to try to clean a 'clicky' microswitch, they may need to be replaced. Either way you have to get inside the unit.
In the past - I have used solventless - plastic safe Contact cleaner applied to the card and then insert / remove card before cleaner evaporates away ..
But TBH - its your risk - I'm just passing on what I have done in past ..
