Charging starting battery from solar?
Akestor
12 May 2018
Athens, Greece
www.youtube.com
Made a simple diagram to connect the starting battery to the solar with a spare PWM controller I already have. Just wanted few opinions about it -if there is anything wrong
Have you considered a Voltage Sensing Relay switch?
Input voltage >13.8 volts and the solar charges both banks. <13.0 volts and the starter battery does not receive any charge.
and link the house and starter batteries together via a manual parallel switch so that if the worst happens you can start from the house battery... switch clusters incorporating isolating & parallel switches and a VSR are readily available.
It would be an interesting experiment to try, but I don’t think the MPPT controller will work correctly.
The MPPT controller needs to adjust the output voltage of the solar to select the maximum power point. The PWM does not have the ability of the MPPT controller to change the voltage. Unfortunately, the solar panel cannot be at two voltages at the same time.
In short, the connection of the PWM controller will prevent the MPPT controller from working correctly, and you will end up with the equivalent of two PWM controllers, or in some situations, the PWM controller may prevent the MPPT from reaching its start-up voltage (+5v over battery voltage).
Why would you want to charge the starter battery by solar when it gets charged in short order by the engine every time you start up?
As you asked. :)
In the UK the weather can be sh1te. From time to time it can be weeks or even months between starting the engine. In that time, for all sorts of reasons, the voltage in your starter battery can go from an at rest voltage of 12.7 volts to 12.2 volts and might not have enough energy to start the engine. To mitigate that issue you trickle charge it.
That's fine if you are using boat often and regularly .... but as many find - its so easy to end up with low voltage on batts and a starting problem.
With such a simple solution of trickle into batts ... what's to not like ?
As you asked. :)
And if it's low it won't "gets charged in short order by the engine". So you end up with a constantly undercharged battery, leading to a very short life.
But isn't the voltage changed after the controller? In my mind at the input side of both the mppt and the pwm , the voltage will be the raw value the panel gives at the moment, for example 16,5 volts. The mppt just reads a voltage it isn't aware a pwm is connected also. Or am I wrong?
Sounds good! I assume the only drawback is that temporarily the house battery will also feed the starter motor as it will be connected to the starting battery ? Until the voltage drops bellow 13?
I had one of these for years on my old boat.
EP Solar Duo-Battery Solar Charge Controller 12/24v 10A. £33.30
I set it up so it would charge the starter battery first, then when that was fully charged - usually not very long, it went to work on the domestic battery. The batteries were linked by a 0-1-2-both switch which controlled which battery started the engine, and a simple cube relay operated by the field terminal on the alternator, so it only made the connection when the alternator was charging. Not as good as a VSR, perhaps, but VSRs were a lot more expensive years ago when I did it.
We're using the trickle charging feature of our MultiPlus. It supplies some power to the starter battery whenever the house bank is charging, whether via shore power, solar, or the hydrogenerator.
A MPPT controller works by adjusting its input voltage (the voltage of the solar panel) to the optimal value where the panel can deliver the maximum power. It then converts this higher panel voltage to a lower voltage suitable for charging the battery.
A MPPT controller and a PWM controller will select similar output or battery voltages assuming the charge algorithm is similar; it is the input or solar panel voltage that is different. With a "12V" panel, a MPPT controller may be keeping the solar panel around 17-18V to extract the maximum power from the panel. With a high voltage panel, the input voltage may be 50V or more. A PWM cannot perform this voltage conversion, so the solar panel needs to be at a much lower voltage.
A single solar panel can only have one voltage at any particular instant so trying to implement both of these options simultaneously is problematic.
I would be concerned re using a VSR simply because the current wasted in operating the relay both in sensing and actual relay coil current may be significant to the total solar current available. Of major concern with a small panel. In fact another small panel just for the engine battery would be the simplest option. Possibly without a controller. ie less than 10 watts.
The proposed circuit may be ok if we consider that at low battery voltage and smallish panel the PWM controller will in fact look like straight through connection.
This means that via diodes panel would be in effect connected to 2 batteries. Only when batteries are charged and there is significant solar panel current available would one controller begin to pulse off and on leaving more current for other battery until it too pulses. Might be ok might get strange effects. ol'will
