Ian_Edwards
Some time ago I converted all my small LED torches from 3 AA or it could have been 3AAA batteries to one 18650.
This conversion has worked well, the only downside is that you have to remove the 18650 to recharge them.
I've been checking the torches to make sure that they are all working and fully charged, prior to the dark nights ahead.
One battery is refusing to charge, the display on the charger says it's supplying 5.163 volts and zero amps, with the battery connected. With the battery disconnected it indicates 5.212v, and of course zero amps.
Is there any safe way of giving the battery a slightly higher voltage to "kick start" the charging process?
I suspect that the torch has been left on and completely flattered the 18650, or is it completely toast?
The battery is a Ledeak 2500mAh, sold by Amazon.
