Andrew_Fanner
The WIF setup sounds like a very wise plan, especially for those of us who must confirm to the BSS and thus tend not to have see through filter bowls. Winter project methinks.
Slightly thread drifting, sorry, but that seems an excellent idea you have there nedmin. Rig up a bag so the tank breathes the same air. Genius! Nice thick bag so moisture can't pass via osmosis. And maybe disconnect the breather pipe from the hull skin fitting so as to make a better seal onto the bag. Maybe put a dollup of silica gel in the bag too.
Very interesting jfm, where does the alarm show? At both or just main helm??Yes, on the primary filters on all my boats, factory OEM, since 2004. Wouldn't dream of not having them because as you say relying on being able to look at yellowish filter bowls is a daft idea. (I also care very much about the veneer; caring about the veneer and the engineering are not mutually exclusive!)
My suppliers said:Stongly suspect it will be 'downgraded' road fuel.
Maybe, but there again the refinery has to continue producing several thousand litres per day of gas oil to send to the airport, so not too difficult to divert some to the marinas.
Having read the directive, consulted the BMF and my supplier, you are the only person who is telling me this. Please demonstrate to me where the Solent is included in Categorised Waters.Nick,
Your customer base is is going to fall into the requrement of the directve as you run a fuel pontoon in the Solent,
I am going to sell what the refinery produce, delivered by the wholesaler, just like the majority of other marinas in the same position, to all the boats who will not be affected by the directive. Subject to confirmation from them, it will not contain any biofuel....who exactly are you going to legally sell the old high sulphur fuel to?
Implementation of this is also subject to ongoing discussion, as I understand it.As to aiports, if the gas oil is intended for 'off road machinery' that will also have to comply with 2009/30/EC come Jan 1.
I agree with this, for boats in Categorised Waters, ie inland waterways. To imply that this applies to all leisure boats, including coastal, is a very much a minority view at present. As such, you should refrain from scaremongering (maybe trying to drum up business?), which causes unnecessary concern to boat owners many of whom are already struggling in the current financial climate.Other than on a few very old engines lubricity will not be a issue. It is just the potential bio problem boaters have to address.
and that in most cases centres around proper filter use - correct?
There are two separate issues here, which seem to be continually ignored and confused.
1) New legislation means a new sulphur free fuel will have to be used by certain groups from Jan 2010.
2) Rather than spend £££££'s blending and storing a new fuel (sulphur free gas oil), it has been suggested that refineries/suppliers might simply supply white road diesel, with an added red marker dye.
The above poses two separate and different sets of problems.
It may of course turn out that marinas based in coastal waters will carry on supplying gas oil as it is now. There seems to a question regarding the wording of "marine" use and whether we fall into the category. I tend to agree with LS1 here, in as much as i can't see refineries/suppliers stocking two different gas oils. I'm guessing that come Jan, all gas oil will be sulphur free. That's my opinion.
Using sulphur free gas oil doesn't mean that we need to take any different action to that which we should be taking already. IE, keeping fuel clean and moisture free and having a decent filtration system.
Point two above is where the significant issue arises for marine users. Here is where i disagree with some of the assertions that are being made. For a start, there is no legal requirement for gas oil to contain biofuel from Jan 2010. It has been speculated that refineries/suppliers will not bother to have two separate fuels, there will be white road fuel for road use and white road fuel with an added red marker dye for all other uses (replacing gas oil). It's the possible addition of biofuel that pose the threat, note the use of the word possible though. The addition of biofuel is purely speculative and as far as i can see was introduced by the RYA statement. This speculative comment seems to have gained a life of it's own and is now being discussed as if it is a fact, including by LS1. There is no evidence to suggest biofuel will be added.
The addition of biofuel would present a number of potential and/or real problems. It may cause some seals and hoses to leak. It may cause problems with certain fuel pumps. It will degrade quicker (it's recommended that it not be stored for more than three months) and with moisture in the fuel it is reported to be promote bug growth. Initial use of biofuel will scour the decades of crud from the bottom of fuel tanks, leading to fuel contamination, filter blockages etc.
Now, given the above downsides to having a biofuel element, consider the user groups for gas oil :
Heating oil (some systems use gas oil rather than kerosene)
Plant and offroad machines, including a host of machines that might be out of use for months on end.
Boats, the majority of which will be out of commission for the Winter months and many will not be used much or frequently during the entire year.
Agricultural vehicles, again some of these will be out of use for long periods, combine harvesters for example.
The above groups must surely account for the biggest share of sulphar free gas oil use. All of them fall far short of the long term storage recommendations for fuels containing biofuel. All would be hard hit by the negative points of adding biofuel. For these reasons, i don't believe that the refineries/suppliers will be using dyed white road fuel, or any form of gas oil containing biofuel. But, that's my opinion again.
Paul,
Nothing at all speculative here, I have been involved with the framing of this legislation since early this decade. Many changes are already in place. Proposals have been implemented by the HM Excise to sort out this potential distribution nightmare. There is to be a new process by which white road fuel is to be 'downgraded' by addition of red dye at the tanker. Whatever level of bio fuel is present in the road fuel you will get it by virtue of this process.
Do not compare properly installed engines in industrial equipment with boats. Smaller tankage and well designed filteration systems. Many boat builders standards are at best poor.
Ah, now I understand why you are so resistant to the notion that it probably wont happen.Nothing at all speculative here, I have been involved with the framing of this legislation since early this decade.
I thought this already took place, Shepperton marina on the Thames sells low sulpher road diesel with a red dye in it, has done for many years.
Will this "new fuel" stop my 180 Sabres smoking?
