I'm interested to see that you have a s/s shackle connecting the low-carbon steel galvanised chain.
When I had that arrangement I was surprised at how quickly the chain rusted. I had the chain re-galvanized and replaced the s/s shackle with an ordinary galvanized one sized with galvanized wire, and it has lasted much longer before beginning to rust.
From memory, 10mm chain is either 28mm or 30mm internal. Yours is presumably the former.Helpful posts thanks guys. Shame the standard isn’t so helpful. What’s wrong with the size of the link as a standard!
So I’ll go back and measure 10 links.
edit that diagram does have the link size I’ve just realised. Looks like 28mm internal. Do you agree?
Thank you.
'I didn’t know regalvanising was a thing.
Any contacts for that? I presume it saved money?
Thanks for the tip on the shackle I hadn’t thought of that.
Indeed so. What would be even more worrying would be for the stainless steel shackle to corrode out the eye of the anchor stock, rendering it useless. Far better to use a galvanised mild steel shackle and replace it every couple of years if necessary.I'm interested to see that you have a s/s shackle connecting the low-carbon steel galvanised chain.
It is very hard to find places that will regalvanise chain. My recent experience was that if you have to pay to ship the chain to and from the place it was cheaper to buy new chain.I didn’t know regalvanising was a thing.
There's a helpful local steel fabricator in Portsmouth who will take in small loads to be added whenever a large job like a fire escape is sent for galvanising, thus avoiding the minimum charge which normally applies.It is very hard to find places that will regalvanise chain. My recent experience was that if you have to pay to ship the chain to and from the place it was cheaper to buy new chain.
www.solocoastalsailing.co.uk
Thanks. Got a name, link or number? Or just a clue??There's a helpful local steel fabricator in Portsmouth who will take in small loads to be added whenever a large job like a fire escape is sent for galvanising, thus avoiding the minimum charge which normally applies.
I use a S/S shackle but I use a bit of plastic pipe over the pin as an insulator.I'm interested to see that you have a s/s shackle connecting the low-carbon steel galvanised chain.
That is interesting, and seems to refute my experience.In over 30 years I have never had a problem with using stainless shackles on galvanised chain.
He's down in the old Eastney Pumping Station building in Henderson Road at Eastney, can't recall the name. Google Earth street view shows Portsmouth Steel Fabrications I think. I don't know which galvaniser he sends it to and I've not taken chain in there, just other bits of steel for a trailer.Thanks. Got a name, link or number? Or just a clue??
