Chain & Shackle.
chappy
23 May 2004
PLYMOUTH ENGLAND
How do you measure the width of your anchor chain, is it from outside to outside or do you measure the gap in between, & also how do you measure the size of a shackle , for example a 3/4 inch shackle where is the measurement taken from.
Talbot
23 Aug 2003
Brighton, UK
and if you are measuring the thickness of the rust - you should probably replace it /forums/images/graemlins/laugh.gif
seriously, if you have an electric/manual windlass, the size can be critical You realy need to ensure that the link is calibrated to the windlass. for example 3/8" and 10mm these are not interchangeable despite only 0.5mm difference. The wrong chain can cause it to jump off the gypsy when under load.
ShipsWoofy
10 Sep 2004
Chappy, as you appear to be building a new anchor system you might like to have a look at some results of polls we filled in on the forum around January. Might give a little inspiration.
Click on the address in my signature below and all should become clear.
hope this helps.......
