gaffer61
New Member
As you may have gathered from my bedding compound post I am about to bolt together all my center line timbers. I Have worked out all my bolt positions except the the lowest stern post bolt which won't pass through the stern post and the two knees without fouling the other knee bolts which pass down through the keel. I have considered using a blind bolt drilling through the stern post and part way into the knee and then chiseling a pocket for the nut and washer. My concern about this is that once the planking was completed the nut in the pocket would then become inaccessible and this as far as I can gather could be bad news if bolts needed to be removed latter. As an alternative I plan to drill a 10mm hole through the stern post and part way into the knee, some 200mm, and then drill this same hole out to 1/2" except for the last 150mm. Putting a 125mm of thread one end of the 1/2" bronze rod I am using for the bolts and enough thread on the other end for a nut, the length of rod being 25mm shorter than the hole drilled. Then tapping the rod in until it meets the smaller diameter hole and then winding the bolt home with a spanner thereby taping into the smaller hole and pulling the stern post tightly up to the knee. The timber in question is opepe. Can anybody see any problems with this method of bolting?
