daveyw
I like blue so I got a Nanni!
Check out Scott at T S Marine.
The installation was perfect as has been the engine. All service components easily accessible.
Just a satisfied customer
Thank you all for your input.
I will be heading down to Mike whatsisface at Brighton on monday morning to order the new Beta 20.
...However, I did notice that the alternator was rather petite, so the optional bigger one, if still an option, is not really optional...
I didn't think it would be long before someone claimed Beta was the bees knees. The truth is that both Nanni and Beta are very good - and based on exactly the same engine. My advice to the OP is to fit the one that suits your installation needs and allows you to get to the ancillaries and service points.
Check out Scott at T S Marine. He installed a Beta BZ482 in my 29' Kingscruiser in 2005.
The installation was perfect as has been the engine. All sevice components easily accessible.
Just a satified customer
No problem - I just find some of the Beta comments slightly annoying. People seem to think that because it worked for them in their situation it must be right for all situations and that patently isn't true.To be fair, I didn't claim Beta was the bee's knees. As I stated, its just what I chose when getting rid of the old Bukh and have been very pleased with it so far (except of course for the faff of cleaning the heat-exchanger every year) and I'm sure Nanni is just as good.
I am amazed that the same engine only in a different colour can generate so much heat in discussions
maybe 14 years is a bit excessive.I think two yearly inspection/cleaning is what we will do
Within a year? And there was me thinking we had gone over to fixed term parliaments, or perhaps that hasn't been introduced yet?Not only engines, my friend! Here, half the country is 'Red' while the other half is 'Blue'. General elections within a year beckon and it has already started with heated 'discussions' being the order of the day.![]()
I note that heated might be apposite in some of the Beta engine discussions considering the various comments about heat exchangers that people are making...
I am amazed that the same engine only in a different colour can generate so much heat in discussions on these forums.
What and why are inertia rings and flexible thrust plates, pray ?an inertia ring on engines less than 28hp, flexible thrust plates etc etc
I wasn't aware that Nanni didn't fit these things. But I'm not a Nanni rep - nor do I wish to defend them. I am only a forumite that gets occasionally and very slightly irritated by some of the posts extolling Beta as the best thing ever when I have been very happy with the engine that Nanni supplied me many years ago and the service I received from their agents.Inertia rings are over pulleys that act as flywheels in the smaller engines which smooths the engine acceleration and deceleration and also allows some of the models to fit polyvee belts, good for wear and heat dissapation.
Their thrust plate is like a flexible coupling between the engine and gear box, so the thrust of the prop is cushioned before it reaches the engine as isn't transmitted directly from the gear box to the engine if you connect the engine without a flexble coupling (and more protected if you do).
Had two very bad experiences with Nanni/Peachments. My friend with a Beta has had problems, but Beta appear to respond very quickly to resolve issues.
