Assassin
Has anyone any experiences of these engines, their problems/issues as the new boat has them fitted, so would like to be aware of any potential problems.
Rated at 1150 HP.
Rated at 1150 HP.
i have found that winding the speed back a little gives a excellent compromise between reasonable pace and consumption, and it accelerates well from all speeds.
It is a noisy engine, the usual high speed diesel combustion clatter is evident, but the boat is well soundproofed so noise is not really an issue, i don't think the thinwall technologies now uses contribute to noise suppression anyway. This is a foible on all newer high speed diesels, not just Cats.
Certainly do not agree that it is a modern engine foible. European engines do a far better job.
C18 is just 3406E with a dose of attitude. Bore went from 5,4 to 5.7 and new crank increased stroke from 6.5 to 7.2 hence the high piston speed. The big issue was that 3406 was a low cam in block motor converted to overhead cam, front cam gear drive is a little clunky and a BIG noise producer. My old chief engineer was at one time senior draughtsman at Henry Medows; he rightly asserted that the only place for the timing gears is on the back of an engine.
CAT's other problem is noise reduction by using injection rate shaping, CAT made exit of the US truck market due to inability to get their feet on the pedals for EPA 2010 emissions. CAT is running a C15 with common rail in Navistar test labs with some good results. ACERT was an expedition up a blind alleyway.
