meracus
hello
any thoughts on reliability , performance and comsumptions of these engines from 1996
regards
andre
regards
andre
hello
regards
andre
My understanding is that the 3176 is actually based on a significantly smaller block - about 10 liters vs. 12 of the 3196.For what I know of the 3196 (which is the same engine with more HP 660hp vs 600) I can say they are very reliable and performing engines and quite advanced for its time.
What I don't know (and I'd be curious to hear) is whether the latter shares the same problems that LS1 mentioned for the former.
In fact, the 3196 has been widely used by several builders, like Ferretti and AZ to name but a few, on some of their most popular models.
For instance, Deleted User of this parish had a 3196 powered Ferretti, and he was happy about them.
Otoh, when I read LS1 using terms like "curates egg" and "problem child" for an engine, that's enough for me to prefer something else, if possible.
Hence my curiosity about how similar the 3176 and the 3196 really are...![]()
in my earlier post about a man powered sarnico ..... the mention of " better to look for a cat powered one .....) most of the cat powered ones have a 3176 on ! a little confused
can a 3176 be rebuilt with better parts for instance ?
thanks
They tell you this cause Cat parts are cheaper to Man ones, as are the mechanics. The Sarnico 45 of same vintage should had Man 610hp.
That's a lovely boat btw, with quality second to none.
Also the Cat was a bit lighter and usually gave a knot or two of extra speed. Sarnico 45 was also available later on with 3196, C12 and Cummins.
dancrane is right in pointing out her declared speed, because calling it miraculous is an understatement. Of course, it would be neither the first nor the last ad where the actual top speed of the boat is much lower than declared.
