Catenary - would you buy krypton piano wire?
As you go to thinner chain the greater movement an abrasion on the bottom is very obvious underwater, and I think this biggest factor contributing to the earlier demise of thinner high tensile chain.
I think this an important point that should be understood by anyone moving to the higher tensile chains.
If I understand correctly G7 "High tensile" chain is produced by creating a compression layer on the outside surface of the chain. The loss of, for example 1mm in diameter of 8mm chain is obviously more significant than the loss of 1mm on 10mm chain, but unfortunately in G7 chain it is the outer layers that are in compression. Therefore the loss of these outer layers caused by corrosion will have a very significant impact on chain strength. If the outer high compression layers are lost the chain effectively looses its high tensile properties.
For these reasons I think we need some caution with high tensile chain. It should be replaced at the earliest sign of corrosion. Given the advantages of significantly lighter weight G7 and G7+ chain is still a great option for boats where chain weight is critical, but I don't think it is the global panacea that is suggested.
I think some of this might be misleading:
There is no suggestion anywhere I have seen that G80 or G100 is a global panacea. For example it would be wasted on many vessel for whom weight and space is not an issue.
G70 chain, or the steel, or the cross section of the link is homogenous. The structure of the steel is consistent through the link. There is no 'compression' layer on the outside. To have a steel of a different physical structure would result in stresses between the layers. The whole basis of the temper is to produce a crystal structure to impart strength, not to produce an outer layer different to the bulk of the steel. Tempered steel, including chain, is produced in different thicknesses (and strengths) and to have an outer layer of one strength and an inner softer layer is simply not feasible. The strength of the steel is the same through the steel. You can see this in broken samples - there is a homogeneous break.
However all galvanising is an alloying process, or that is what happens, and the galvanised layer is actually composed of alloy layers of different compositions. The inner layer has the highest Fe content (of an FeZn alloy) and subsequent outer layers have less and less Fe - the outer layer is pure, or nearly pure zinc. The inner layer - the one that forms next to the base Fe, or steel, is very thin, a few microns and the exterior layers are less and less hard, though commonly harder than the base steel.
In use the outside layer of Zinc is soft and abrades easily but it does also serve to protect the under layers, because it is malleable. For structural steels this is advantageous - because it does not suffer abrasion but for anchor chain the outer layer is transitory and soon wears off.
The life of the galvanising is commonly a function of 2 factors, how well it is adhered )or how well it is alloyed) and how thick it is. Common standards of thickness are 70 microns - which is effectively based on engineering applications, structural steel work - where there is no abrasion. Our chain is made to the same standard, if you are lucky maybe a bit higher than 70 microns (by chance rather than design) and sometimes lower, I've seen 60 micron specs. But life of our chain is a function of the thickness of the galvanising. You can produce a thicker galvanising layer, but zinc costs money and we are small part of the market. If the layer is too thick - it can flake, and life of the coating then reduces. If there is inadequate preparation the alloying layers are not well formed and flaking can also occur.
Maggi had a poor reputation for galvanising - there were complaints of their G70 chain (of which Noelex has direct experience) and of their G40 chain (which have been reported on YBW). It does not appear to have anything to do with steel quality - but process. I noticed on samples I had a propensity to flaking - indicative of poor preparation - the chain was insufficiently clean before galvanising. Gal poorly adhered will break off on the seabed, and even in the gypsy.
These same complaints are not evident, or not so consistently, for other chain makers, American nor Chinese whether G70 or lower grades.
But returning to the FeZn layer that forms the interface between steel and gal. This is a very hard layer, and very thin. It has no impact at all on strength of the chain. But when it is breached - there is only steel underneath - and it will corrode.
Really as soon as you see rust developing on your chain you should then prepare to regalvanise as you are looking at raw steel and further use will abrade the steel and reduce strength.
However High Tensile steel is factorially harder than G30 steel - and weight for weight - the HT steel will last longer (though both will corrode at a similar rate). How fast 6mm chain in use abrades compared with 10mm chain is an unknown - you can guess but there is no basis - so your guesses are, simply, guesses. Because the HT chain, in this case, is lighter, and harder (and will be on the seabed for a shorter time - the steel (and the galvanising) will last longer. Or because the chain has a lower surface area it will abrade more quickly. To complicate - the galvanising on HDG is softer than that proposed for HT chain.
Instead of guessing - I'll conduct some tests.
There is another wear mechanism, for gal - and that is chemical. Some seabeds, primarily mud, are anaerobic and acidic. The chain can be chemically eroded. If you chain comes up black - its probably been in a sulphur rich environment. Hardness does not come into it - thickness of coating is important.
Dashew has been using G70 chain since the 70s or 80s - he has never suggested that galvanising life of the chain he uses, ACCO, now Peerless, has been an issue. Other people have followed his lead and also use Peerless G70 chain. No-one has ever highlit galvanising life as being an issue, specifically for G70. The users of G70 without exception have moved down a size, to a small chain - if there were serious issues with the life of small chain - it would be known, be the subject of internet discussion and Dashew would be defining his use of the product on the expedition vessels he sells.
I think both of you are falling into the fallacy of good equations but wrong assumptions (in my view) re catenery as the difference in catenery between 6mm and 10mm is very small in the kind of wind forces where it matters. The assumption which I think is incorrect is ever looking at the need to keep any chain on the bottom - ie. 0 degrees to the horizontal. Once you accept that even CQRs can cope with 10-15 degrees and keep digging and Rocnas nearly double that then you realise that scope is king of setting a good angle, not weight of chain and catenery (which of course exists, is proportioanal to chain weight etc etc ... I completely agree with the maths but with my assumptions it leads me to a different conclusion).
Rupert,
We do not disagree, above about 20 knots most of us knowingly or not, have all the chain off the seabed, unless you have deployed a lot of chain and its very heavy. But with 30m, of a chain recommended for your vessel, deployed at 5:1 scope its all off the bottom at 20 knots. I know I've checked the actuals. At 30 knots that same chain and same scope the chain is effectively straight (I know its never straight) and you may as well be attached to your anchor, well, with kryptonite piano wire.
Jonathan
Q&T HT, G70, rather than G80 or G100, in commercial vessel anchor chains
https://rules.dnvgl.com/docs/pdf/dnvgl/ru-ship/2017-01/DNVGL-RU-SHIP-Pt3Ch11.pdf
Check VL K3 chain.
It not novel, used and accepted
I don't find it relevant - but just clarifying
I don't see that the normal application of lifting chain being different to our usage of chain as an anchor rode automatically denies its usage. If the characteristics match the application - why not.
Its strong, can be light, it can be galvanised, its tougher (has better elasticity - so absorbs more energy), is made to a size to match our gypsies.
There are questions, abrasion resistance seems to be a fundamental factor - but the overlap seems too high to ignore.
Are there other factors?
Jonathan
I have seen some German anchoring systems using a weighted webbing strap and also American winch system using steel cable.
I know the latter is intended for fishing stops but I am not certain about the German system.
I do not think that these are intended for anchoring in a F8 but it does show that there is some thought going in to not using the traditional heavy chain.
If the anchor is doing all the holding provided there is the strength in the boat attachment then why do we need to have the weight?
Is it just a tradition or not using modern materials to their best advantage?
Ps I have chain on my boat and do not need to spend the money to change. I am just trying to understand why people do not like the idea of change.
You have also ignored toughness. A high grade chain can absorb nearly three times as much energy without damage. It's in the specs.
The problem with many of your conclusions is that you seem to be comparing G7 or G7+ chain with the same size G3 or G4 chain. You should be comparing G7 or G7+ chain with thicker G3 or G4 chain.
Cruisers are trying to decide if, for example, they should use 8mm G7 or 10mm G4.
If these two types of chain are compared, when anchoring the 10mm chain will move around less on the seabed. Hence the 10mm chain is subject to less abrasion and the galvanising will last longer. In addition, for the same amount of corrosion, the 8mm G7 will lose far more strength than the 10mm G4. The boat with the 8mm G7 will also move around more. If there is a wind shift, the boat with the 8mm G7 will move to a new location quicker than the boat with 10mm G4. If using thin chain for your boat size, it can be a problem swinging differently to most cruising boats.
The boat with the 8mm G7 will also have less catenary. This has a couple of practical effects. When the anchor is in the critical early setting phase, the chain angle will be significantly higher. This makes the initial digging in of the anchor more difficult. The second effect is in poor holding ground, especially in deeper anchorages where the higher chain angle experienced in light to moderate winds on the boat with 8mm G7, will reduce the holding of the anchor and/or require more scope.
The 8mm G7 will be harder to buy or replace, especially in out of the way places and a new gypsy will also be required.
The advantage of the 8mm G7 is that it is lighter. As the chain weight is significant and this weight is stored at the bow, this is a substantial advantage. The weight in the bow can be significantly reduced by switching to thinner G7 chain. Alternatively, many boats reducing chain size take advantage of the lower chain weight to increase the size of their anchor and/or increase the length of chain carried. Both of these changes have significant advantages for a cruising boat. There is also some evidence, especially in softer substrates, that thinner chain will help the anchor penetrate deeper.
Most of the advantages and drawbacks listed above will not apply to the lifting industry, or at least they take on a very different significance. The service requirements of the lifting industry are very different. They don't even need to galvanise their chain.
Only a tiny fraction of boats use G7 or G7+ anchoring chain, which is a pity. I think it is an excellent choice for some boats. However, when suggesting these types of chain we should recognise that are drawbacks as well as advantages.
We're just going to have to disagree.
Fair enough :). I hope people considering which chain to use find these type of discussions helpful. The number of people that have used G7 anchor chain is very limited at the moment so there will naturally be some disagreement concerning the relative merits of this choice. As long as the posts are polite and respectful (as yours always are, Thinwater) I think there is merit in threads such as this. If nothing else, it may convince more people to try G7 chain.
A few thoughts....
Sleeping well IMHO is aided by knowing there's a load of metal between the boat & the anchor which isn't going to chafe through in a hurry.
If you have something very light and everyone else in the anchorage is on heavier chain then you'll dance around much earlier and much more than your neighbors.
And guessing, without dragging around some chain as you tack back and forward in a blow the boat will accelerate more and be going faster when it gets turned by the anchor, energy is proportional to velocity squared to could well led to significantly higher loads on the anchor when the wind gets up.
Setting of anchors - when I see people power setting anchors the tension in the chain is such that it looks 'straight'. When I see underwater video of people setting anchors the chain is lifted off the seabed - and looks bar tight. I have watched setting of anchors with basically, effectively all rope rodes, with a few metres of chain and some with wire rodes - even at short scope - the, modern, anchors set without issue - and rode is effectively straight.
You, Noelex, used G70 of a size smaller than would be normally suggested - I don't recall, ever, you suggesting the lighter weight of the chain being an issue. You have mentioned the lack of integrity of the galvanising - but the disadvantages of the lighter rode - not a mention, once. You mentioned lots of other aspects, the slope of the seabed, the poor designs of some anchors, that galvanising but never once (though I confess I could have missed it) did you suggest that you wished you had had heavier chain. Now its almost a deal breaker.
Jonathan
That's why you have a snubber. The snubber is an essential part of the rode, especially with lighter chain. It needs to be a matched part of the system. It cannot be any old bit of rope - it needs thought - as one without sufficient elasticity will be useless (and one with too much elasticity will have a shorter lifespan).
But most of us have lived with yachts with different anchoring characteristics - and survived. Catamarans, LDB, trimarnans, steel ketches, long keeled heavy displacement etc. We have all anchored together in the past - a lighter chain + snubber is just another part of the mix.
Jonathan
Years ago I was a member of a team carrying out wear measurements on a wide variety of metals. There is a direct relationship between hardness and wear resistance, and thus G70 would resist wear to a greater extent than G30.
Also, both G40 and G70 contain slightly more alloying elements than G30, which should give them marginally more corrosion resistance. G70 is a heat treated version of G40 , resulting in a through-hardened microstructure of tempered martensite. There is no surface layer present, other than the galvanising.
Rupert,
Jonathan
You are right, then. We are in agreement.
Years ago when I was in engineering design if we needed a component the be tough but wear resistant we would specify the item to be made of low carbon steel but then case hardened to give a wear resistance surface but still have a tough inner core.
The top quality knives and swords are made by forge welding low/medium carbon steel with high carbon steel on the cutting edges to hardness of cutting edge but a tough core.
having designed chain hoists years ago the chain for a hoist need slightly different properties than an anchor chain. Anchor chains need both wear resistance and limited shock loading. Lifting equipment meed basic strength but also be able to take shock loads. Less so wear resistance. Even the forestry industry as the chains mainly have to resist the wear of wood and soil not so much rock and coral on the sea bed.
Rupert,
Jonathan
Another very simplistic analysis where the boat stays perfectly still in 30 knots of wind.
How many of us have seen this happening in the real world?
How often does anyone anchor with 15 knots or more at deck level and not feel the boat moving at all?
I've measured the impact of being at anchor in 35 knot winds and measuring peak loads, which I doubt many others have done. As I said in the post 'Ive measured the actuals'. At scope of around 2.7:1 peak loads were just shy of 700kg.
If you want the detail its all been published in Practical Sailor. Google and Practical Sailor are your friend.
Jonathan
I'm wondering where those who advocate krypton piano wire live - it's an inert gas, whose melting point is -157.37 degrees C! So to make piano wire of it, you'd need to live in one of the colder places in the Solar System. Maybe Titan is cold enough? Anchoring on a liquid methane lake must pose problems, though!
No, I am not. I never said that. Let me explain.
Regarding toughness, I think the engineering is not well understood. I like chain and I understand all of its merits. Used it for many years. I have not studied the corrosion merits. But for this one post, let us ONLY talk about toughness and why higher grade chains are not just stronger per weight, but better for things involving snatch loads, like lifting and anchoring. Also please accept that on some of these point I must be correct, or ANSI, ISO, and the entire industrial community has been wrong for many decades. These are not opinions but established engineering facts and understanding.
Wear. I think it is obvious that higher strength steels wear disproportionately more slowly than lower grade steels. Would you use a mild steel drill or a hardened steel drill? I'm sure testing will show us, but industrial experience and common sense is that high strength steel wears better. Yes, there may be 1/2 as much steel, but it wears many, many times more slowly. It has the same safety factor.
To an engnieer, there are two type of toughness. One relates to hammer like impacts (Charpy notch), and though interesting, is not really a distinguishing feature here and I will skip over it. The engnieering definition of toughness is the ability to absorb energy. Every steel alloy has roughly the same stretch/strain relationship, regardless of strength (look up Youngs modulous). A higher strength chain may operate at 3x higher tensile load at the same % WLL, correct? Thus, the high strength chain stretches 3x as much. This is not obvious, but it is true. In fact, grade 100 chain stretches about as much as polyester rope at equivalent %WLL. You can look this up. Thus, within its WLL, grade 80 chain (minimum for lifting) will absorb 3x as much energy as grade 30 chain without damage. This means that within its WLL, it is many, many times harder to damage a grade 80 chain with an unintentional snatch load than it is a grade 30 chain. It is perhaps 10x less likely to distort or fatigue. The difference is more than 3x, because the stretch results in lower forces, like using rope instead of chain, although not as visually obvious. This is established fact, not opinion, and it is the reason behind the regulation. Does this make sense, or do we need to investigate whether the regulations are wrong?
So I hope we have settled, from an engineering viewpoint, that high grade chain is tougher than low grade chain when sized at the SAME strength. Those who believe high strength chain is somehow brittle are ill informed and have chosen to disagree with the entire industrial and standards engineering community, which is rather embarrassing for them. This does not necessarily make smaller better, if you like mass. Mass is nice in a crowded harbor. This is a good reason for fixed mooring chains to be huge. But grade 30 chain has no other proven weakness, even when down sized. There are small practical problems where it joins the anchor or rope.
Noelex has mentioned poor galvanising, noted, but not thought relevant, LW has suggested use rope, valid - if there is no coral, nor rock, mention has been made of older style (conservatively designed) yachts, noted in the preamble.
I have pointed out that there is a question mark over galvanising as there have been no tests comparing 6mm High Tensile Chain with the abrasion resistance of, conventionally galvanised 10mm G30. But if that is the only reason not to use HT chain - I am pretty confident it is not an issue, based on my own work (reported in Practical Sailor) and independent work conducted by processors in America and separately the US military.
Jonathan
Where does the query about the galvanising come from. If the same hot dip process is used then the protection will be similar though the consequences of wearing out the galv on a thin chain will obviouslt be worse - HT steel rusts at the same rate as ordinary steel , broadly speaking so 6mm chain will rust through almost twice as quickly as 8mm. For that reason alone I wouldnt want it at the anchor end of my rode in an area where I might find an abrasive botom like coral
The ability of a catenary of chain to absord movement is related to its weight amongst other things. With a chain weighing half as much, snatching will happen earlier and the snubber will need to be a lot longer. There comes a point when you stop messing with seperate and replace the chain between snubber hook and deck with nylon rode. That might be more on an issue here in the overcrowded uk but where you are it shouldnt be a problem.
So to sum up:
1/ 6mm will wear and corrode faster
2/ its catenary effect will be less
I reckon you are solving a problem which doesnt exist.
^^ We have no evidence to suggest it will wear faster. In fact, the reverse is almost certainly disproportionately true. Prima facia evidence is that a hardened steel drill wears better than mild steel, and that hardened steel is much slower to grind.
I'm not sayin' I want G100 chain. Maybe I do not. I'm sayin' lets keep facts as facts.
Corrosion needs studied. It seems plausible that life is slightly less.
Weight has two sides to it. The right balance is probably different for each boat and cruising style; if more were always better, we would all cruise with even bigger chain and anchors... which some do. I refuse to argue this either way, since I believe the answer is fluid.
Hardness and toughness really are not the same thing at all.
^^ I didn't say they were. You inferred that. But I could have said "high strength steel is slower to grind," which if you have fabricated equipment you will accept as factual. High strength steel, such as in grade 80 chain, is much more time consuming to grind and fabricate. That is my revision.
I think you may also be confusing ductile toughness (bend without breaking, but the gear has failed and will break in the next few cycles) with elastic toughness (what a spring does for years).
That is a nice explanation Thinwater, but I am afraid I don't see much relevance to a marine application where the steel is immersed in salt water.
The concern is not that G7 chain corrodes faster because it is softer. No one has suggested that. The concern is that G7 corrodes faster because when switching to this chain the diameter and weight are reduced, but the forces produced by the boat are the same.
The thinner chain is significantly lighter (which is the aim) and therefore moves around more in an anchoring application. This can be seen quite easily underwater. This extra movement creates more abrasion on the galvanising both from the chain links rubbing on the seabed and also from the chain links rubbing against each other. The extra movement and abrasion wears the galvanising and it fails earlier.
The chain wears most rapidly at the apex where the links join. As well as the greater movement seen when using thinner, lighter, G7 chain versus a thicker G4 chain, the bearing surfaces where the chain rubs together are smaller with thinner chain. As an example, think of two round 10mm bars verses two round 8mm bars mated together. The contact surface area is considerably less for the 8mm bars. This surface area acts as the bearing and wear surface, but as the boat size has not been reduced the force remains the same, and compounding this, as the weight of chain is less the links are moving more.
Then, as has been mentioned, the loss of for example 1mm in thickness produces more loss of strength on 8mm G7 chain than the same amount of corrosion on 10mm G4 chain.
Your explanation of hardness of different steels was interesting, but as I mentioned irrelevant to our application. In the lifting industry the hardness of the steel will effect the durability, but in a marine application once the galvanising is lost the underlying steel corrodes quickly. The rusty steel is not tough at all it can easily be rubbed away even on hardened steel. This exposes new steel, which in turn oxidises, and the cycle is repeated.
The hardened steel on your drill bits or tools might be very tough and abrasion resistant, but leave these in a salt water environment and a corroded mess with loss of steel will rapidly develop. The toughness of the steel is irrelevant. Unfortunately, I have inadvertently tried this experiment for myself and can vouch for the outcome :).
