thinwater
^^ Corrosion. Never debated that and I said that I would not. It is better to see data. What you said is generally obvious. I would also bet lunch only a few % of the people use their chains that hard or keep them that long, and this is only a problem if you do BOTH (corrosion and enough use for it to accelerate wear). You do, but few people cruise that much. I see a lot of tiny anchors in marinas that assure me they don't go far!
Toughness and elastic elongation. 200 feet of grade 80 chain will stretch 3 feet at the WLL, while grade 30 will stretch only 1-foot. That is the difference for the lifting industry. You have to admit that is interesting, since chain only fails when they are snatch loaded (can't prove that, but I think it is very nearly self evident). I'm surprised that no one has discussed this variable. You can rhetorically dismiss the issue by switching the discussion to hardness--which is a separate issue--but there it remains; high strength chain is more elastic. I think we are dismissing that rather casually, without discussion.
The best answer? It depends on the boat. My last boat I would not have used grade 80 because grade 43 was enough and grade 80 was not available smaller. There was no need to ponder. My current ride makes more sense with rope--chain would be massively stupid. I suspect the universe of boats were grade 80 is the smart choice is limited. But I'm not in the fight.
