VicS
Something I had in mind to check out today. As far as I have been able to discover there is no problem and the aluminium wont dissolve in the molten lead.I'd worry about aluminium dissolving in the molten lead. I am not metallurgist enough to know if this is feasible or even likely, but enough metals are mutually soluble for it to be a possibility
If recycling old lead pipes, the presence of a solder join will reduce the melting point of the lead, and you may get tin separating out as the metal cools.
Tin as such wont separate out. Small amounts of tin form a solid solution with lead. If a molten mix of tin and lead, with less than 62% tin is cooled the lead rich solid solution with form initially The composition of the liquid will become increasingly tin rich as this happens and the temperature falls. At 183C the liqid will contain 62 % tin and will then solidify at that temperature forming the typical eutectic structure.
The tin/lead phase diagram is easy to find , is a very simple one and explains all.
