Cascover Theathing
andrewh
25 Jul 2004
Can anyone tell me anything about Cascover Sheathing? What is the fabric, what is the glue, is it waterproof, what do you do if it becomes damaged/unattached, etc?? Thanks.
howardclark
16 Sep 2001
S. Wales
I've recently bought a sheathed boat - If its loose in local patches it can be stuck back with West Epoxy (according to my surveyor). Not sure of the actual nature of the material but it seems extremely tough. Its going out of fashion as its more common now to fibreglass sheath. If you lost a whole section just replace with fibreglass but if yours is as tough as mine it will not come off!
If you have real problems E-mail me and I'll pass you the name of the guy who built my boat who is both highly experienced and very helpful. E-mail is corralinn@ntlworld.com
Bergman
27 Nov 2002
The sheathing material is nylon and it is fixed with Cascamite adhesive.
Or so I have been told.
I think Cascamite is a water based waterproof adhesive that I once used many years ago to build model boats, sort of white powder stuff that you mix with water.
burgundyben
28 Nov 2002
Niton Radio
I have some info about Cascover, a sales brochure that is quite old, I could foto copy and post to you, send me a PM with your address if you'd like a copy.
......girls, girls, get back, please, one at a time......
Mirelle
N/A
30 Nov 2002
Re: Cascover Sheathing
Nylon cloth, stuck on with resorcinol (originally Cascophen) glue. Still available/repairable, I am told by Robertsons here in Woodbridge. Presumably any other first class wooden boat yard will also do it. Done as a precaution against teredo worm. Better practice for wooden boats than glass cloth and epoxy, since more flexible and epoxy is no longer seen as the wonderglue these days.
anmarine
24 Jun 2002
Berkshire
Sorry to enter this one a bit late. Cascover is a nylon sheeting, the prefered adhesive being Cascophen. I have worked with this product on several occassions without to much problem.It was a good product if correctly applied, and is still very serviceable after 40 years. Epoxy is not a good adhesive as it has a weak bond with the nylon sheathing. Cascophen is readly available and should be used. Epoxy and GF matting or tape can be used on top of the sheathing to form a repair, providing the sheathing is well roughened and cleaned prior to application. This works well on hard chined boats where the covering has been damaged due to careless lifting etc.
hrau13
1 Oct 2007
I would like to know if Cascover is still available and where I can order it.
I am rebuilding a Arthur Robb Ketch and I like to replace what I had to remove for the repairs
Thank You...............
