car adaptors
cnh
18 Oct 2003
I have just bought an accessory for the boat which has a car cigarette plug at one end. I'd like to snip the plug and replace it with a Driplug. Does anyone know how the cigarette plug is wired - i.e., which is + and which -?
Many thanks,
Nicholas Hill
Usually the middle contact is positive.
Steve Cronin
<hr width=100% size=1>The above is, like any other post here, only a personal opinion
insider
23 Jun 2004
bristol
normally centre, which unit is the cable for?
<hr width=100% size=1>Logical progression is fault finding tool in every tool box.
Regards,
Insider
Jools_of_Top_Cat
16 Dec 2002
be aware though that the equipments fuse is now usually fitted in the socket and it would be prudent for you to fit an in-line fuse if you are removing socket.
Older equipments would have a fuse on the input inside the case, but this seems to be a thing of the past.
We have been using car accessory sockets on board now for 3 years without problem, makes using 12v appliances much easier. Even the one in the cockpit is still going strong without visible corrosion.
I guess it depends how sheltered you are.
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>
</A>
simonfraser
13 Mar 2004
some of the springs in the plugs are a bit too stiff and push it out again, shorten the spring slightly, that seems to work.
my external adaptor still works fine after 4 years, exposed to salty water too.
centre should be positive, use a multimeter if you are not sure.
Talbot
23 Aug 2003
Brighton, UK
You should also be aware that some of these plugs also contain a diode to hold the voltage down to a specific figure.
cnh
18 Oct 2003
Many thanks for your replies. I was fairly sure that the centre would be +, but needed to check.
Simply computers do a rather nice dc dc converter, and it even fits my IBM laptop, which I use as a chartplotter. Also nice to be able to watch dvds where there's no mains!
Maplins do a Notebook dc - dc convertor ..... 24.99 ....... excellent and fits most makes and voltages.
I use this for my charting on PC and an invertor - 150W - to power my printer. Having also to use my PC and printer in car when working / travelling - I find this excellent combination.
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
