Corsaire
Hi all, Looking for advice, hints, tips, do's and don'ts for canning / putting up foods. Never done it before so all information will be appreciated including recipes and equipment recommendations.
Sounds horrendous. A recipe for food poisoning.
Think we will stick with the fridge and freezer.
Botulism and other forms of food poisoning don't always smell bad
Is it possible for any kind of bacteria to grow with the seal still fixed airtight under a vacuum?
I've never had anything canned loose the seal but if it wasn't sucked in tight then it would be straight over the side.
Absolutely, if the bacterium is inside the jar at the start and it is not heated sufficiently for long enough to kill it or the spores.
But can the bacterium live without creating gas increasing the pressure, or rather decreasing the vacuum inside the jar so the cap isn't sucked in?
Yep.
.' Some microorganisms that grow in canned foods, however, do not produce gas and therefore cause no abnormal appearance of the can; nevertheless, they cause spoilage of the product.'
Taken from https://www.fda.gov/food/foodscienceresearch/laboratorymethods/ucm109398.htm
They are harmless with regard to food safety, but they cause the food to ferment in a way that produces a sour off-taste and smell without producing any gas. Metal cans will not bulge, nor will lids pop off of jars as there is no gas to cause that.]
