Can someone explain why my topping lift is designed the way it is.
mocruising
21 Mar 2004
TURKEY
A line goes from the neck of the boom (Close to the mast) down the inside of the boom round a pulley at the end of the boom and then up about three meters round a block and back down to the end of the boom where it is fastened. A second line attached to a cleat at the base of the mast rises up the mast internally round a pulley at the top of the mast and back down to the block from the other line. Why so complicated. A single line up the mast (internally) round the sheave at the top of the mast then down and shackled to the end of the boom would be just as good surely. I am replacing all my running rigging.
yoda
12 Dec 2001
Tamar river, Devon
It's all about purchase. From what you say you have a 2:1 purchase which probably avoids the need for a winch. That said I have what you propose on a 34 ft boat and it's fine for me. Stick tote KiSS principle and you can't go too far wrong.
Yoda
VicS
13 Jul 2002
As above. hauling the first of those two lines will give you a 2:1 advantage. Hauling the second just a straight 1:1 ratio.
Why would you need a 2:1 purchase ?????? Very heavy boom ??
Blueboatman
10 Jul 2005
If you fit a spring or gas vang, then the topping lift becomes a spare main halliard and no longer interferes with the roach or airflow.. Just sayin' like..
Javelin
3 Sep 2010
Southwold
www.Southwoldboatyard.co.uk
One other possibility is for the 2:1 feed to then run down the mast to a turn block and back to the cockpit.
Therefore allowing you to alter the topping lift from either the mast or the cockpit which at times can be useful.
neil1967
28 Nov 2007
Tavira, Portugal
I had a similar arrangement on my Oyster 406, except that the line (wire) from the top of the mast was fixed at the top, and there was a 2:1 purchase inside the boom as well. I removed the whole lot this winter and now just have a 'normal' topping lift - not been for a sail yet, so I can't vouch for it, but the 12mm topping lift hasn't snapped yet!
Neil
Daydream believer
6 Oct 2012
Southminster, essex
I had a short block & tackle (3:1) on the end of my Stella boom with a simple cam cleat . It was great for adjusting the length without having to go forward as I could adjust it just as it hit me on the head
PetiteFleur
29 Feb 2008
Suffolk
That is what I have except that I use a Barton Boom Strut, nothing to go wrong or need replacing, cheaper and very simple and effective - the KISS principle........ I just have the old topping lift tied to the backstay as a spare main halliard if required.
