Can I recut a baggy main?
jimi
19 Dec 2001
St Neots
I've got 2 mains a goodish one and a slightly baggy one, I want to use the old one in the winter so if it gets blown out its no great shakes. However the draft is well back and more heeling & less drive in windy weather (just when you want it) .. is it possible to get it recut or should I just turn it into a gazebo?
BobE
15 Jan 2002
Hampshire (West)
James
At this time of night you can do what you wish but I suggest you sleep on it. Not the main but the idea.
Night night Cheers Bob E..
27 May 2002
Re: X-Cut?
I am in the process of buys new sails.
Hood claimed that one benefit of choosing their Vectron/Xcut sails is that a cross cut sail can be recut.
Cornishman
29 Jul 2002
Cornwall
The cost of the job might not be worth it, especially if it is vulnerable to being blown out as you suggest. Get an estimate would be my advice.
clouty
27 Aug 2003
Shoreham again
janeclout.com
If it was always baggy, and the sailcloth is in good shape, then I think it will be worth it. If it is baggy because the sailcoth is giving up, then it would be good money wasted.
<hr width=100% size=1>clouty
jimi
19 Dec 2001
St Neots
So if its got baggy because its stretched then esentially its not worth recovery?
powerskipper
18 Sep 2003
Dorset/ Hampshire. south coast
www.facebook.com
Shaggy mane , would a barber not be more helpful.
OOPPS just put my glasses on /forums/images/icons/wink.gif
<hr width=100% size=1><A target="_blank" HREF=http://powerskipper.mysite.freeserve.com/>http://powerskipper.mysite.freeserve.com/</A>
Julie
robp
That's what a sailmaker told me. By the time you've spent maybe a few hundred re-shaping it, you will only have an old sail re-shaped. Plus, you can get a new one for not that much more.
Mudplugger
12 Jun 2003
East Coast/ North Sea
IMHO I would disagree with the comments that say it's not worth it, The last time Dolphin recut & repaired a blown out spinnaker = £45.00 (800') and recut Main £50. Providing material is good! should not be an expensive option. HTH Tony W.
<hr width=100% size=1>Tony W.
BlueSkyNick
29 Apr 2003
Near a marina, sailing club and pub
How old is the sail in question?
If it is only the same age as the boat, and not been in full time use, then it can't be so baggy can it ?
You sure its not hypocondria (sp?) again?
<hr width=100% size=1>I can't be bothered with a footnote - it's usually rubbish anyway.
jimi
19 Dec 2001
St Neots
Sail is about 4 yo and has done c. 7 thou miles. Never was entirely happy with the shape anyway as I felt the luff was too tight, and point of max draft if c 50% s/b closer to 30%
dom
17 Dec 2003
I am not sure of the setup on your boat but sometimes increased mast prebend coupled with high halyard tension can pull the centre of effort forward enough. If the sail is the original Beneteau supplied Dacron that has stretched I would not spend more money.
charles_reed
29 Jun 2001
Yes indeed you can easily if it is a crosscut and with more diffuculty if it's a radial.
I'd consign it to a decent sailmaker for the job, and whilst you're about it I'd suggest you have it converted to a loose-footed sail, getting rid of the bolt rope.
Not only will you have a better sail, the job will be less costly.
Ideally loose-footed sails are full-battened - but that can be quite expensive and full-battened sails are far more flat-cut than t'others.
Mind you the extra drive you get from fully-battened sails might give you quite a fright.
jimi
19 Dec 2001
St Neots
Re: Elvstrom
Awa and bile yer heid ye short stumpy palooka! Its a swedish name and everyone knows that anything from Sweden is beyond reproach
Beagle
20 Apr 2004
Holland
Re: Elvstrom 2 types
Type 1: that's made by the same Nike employers, under (probably) the same conditions with the same expertise. This one's cheap & nasty.
Type 2: Custom made in Sweden.
Guess what type is delivered as standard for most production boats???????
<hr width=100% size=1>I came, I saw, she conquered (the original Latin seems to have been garbled).
NigeCh
28 Feb 2002
Mortehoe
Best suit ... Old suit
Jimi, you already knew the answer before you asked it. But before you ditch it, how's the elasticity on your standing rigging ?????
