Can I connect the battery charger directly to the VSR?
Colvic Watson
23 Nov 2004
Norfolk
We have three battery 'banks' - house which will be 330ah, starter 110ah and bowthruster/windlass at 110ah. This winter the thruster battery got quite low because I forgot to isolate it. I thought about connecting the Cetek 25ah charger direct to the VSR (one of the newer type with almost no voltage loss). That way like the alternator it will send the juice to wherever needs it most. But is there a problem I haven't forseen?
JumbleDuck
8 Aug 2013
SW Scotland
Yup. Most VSRs are dual sensing for just this purpose: you connect the alternator to one battery and the charger to the other and the VSR connects them whenever incoming current pushes either battery high enough.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
That way like the alternator it will send the juice to wherever needs it most...
It doesn't work like that, it is a common misconception that a VSR "decides" what to charge. The VSR will switch and simply connect all the batteries together. If you only have one shore power charger, this is what you want. However, with three banks, you need more than one VSR.
pampas
17 Jul 2003
Falmouth
Not so mine has 3 studs for each battery.
In reply to the question "Can I connect to the vsr"( At the alternator input connection) yes provided you disconnect prior to starting your engine,
halcyon
20 Apr 2002
Cornwall
All VSR's are virtually zero volt drop, are you talking solid state ?
Assume a single output charger ? you need a twin relay VSR, with mains charger connected to service battery. This allows charging from engine or mains charger to all three battery banks.
Brian
halcyon
20 Apr 2002
Cornwall
The batteries decide what is charged, the VSR only provides the means. As the engine battery is normally at a higher capacity than the service battery when the relay engages, charge will go to the service bank until the service approaches engine battery level, least line of resistance. Today with high capacity alternators, this does not work as well due to surface charging of service battery, faster you charge a battery the lower the charge it excepts.
Colvic Watson
23 Nov 2004
Norfolk
I hope I've used the right terminology.
The VSR has four studs, alternator and three positive output studs, one for each of the three 'banks'. The whole boat uses a common 12v negative. I assumed that if I connected the positive lead from the battery charger to the alternator stud and the negative to the house bank then it would be as if the alternator was feeding the VSR. What would happen if I forgot to switch off the charger before I started the engine?
VicS
13 Jul 2002
Are you sure you are describing a VSR ..... not a 3way diode splitter?
What is it exactly ...... make and other marks/ name/ numbers
is there a negative connection as well as the 4 connections you already mention..... if not its not a VSR
halcyon
20 Apr 2002
Cornwall
He's describing a diode type splitter.
It depends on the mains charger electronics, they may need to see the battery voltage to regulate, so the solid state splitter may not work, or may need some fiddling.
Brian
20 Jun 2007
The VSR has four studs, alternator and three positive output studs ...
Sounds like a diode splitter to me, not a VSR. A VSR has just two battery studs, one (or both) of them will also sense the voltage, there is no stud for an alternator. In addition there is a low current negative terminal. When activated, it joins the two studs together. An alternate charging source can be sensed in the same way.
VicS
13 Jul 2002
Crikey - it sounds like a diode splitter - will it work with that?
The snag with diode splitters is the volts drop across them.
It can be overcome as far as the alternator is concerned if it is battery sensed. It will then deliver the correct voltage at the batteries.
Probably the most satisfactory solution as far as a battery charger is concerned is to use one with three outputs.
For other charging sources eg solar or wind to use a regulator or regulators with three outputs
Alternatively of course change to a VSR controlled system
